Results 1 to 14 of 14
can my alt handle this
This is a discussion on can my alt handle this within the Audio/Video Electronics forums, part of the General Discussion category; Ok, heres the deal i'm tryin to rebuild my system on a budget. And i decided i want 2 10" ...
    Forum Leader nebraskaz71's Avatar
    Aug 2001
    nebraska
    Ok, heres the deal i'm tryin to rebuild my system on a budget. And i decided i want 2 10" L7s most likely and probably a jbl 1200.1 since i can gte both real cheap compared to most places. But if i run the jbl 1200.1 and a small amp for components on my stock 105 alt with biggest diehard gold is it gonna be able to take it? Are my lights gonna dim and battery die all the time? What if i upgrade power wire from alt to 0/1gauge will thta do any good? I can't afford to dual up batteries or get bigger alt so i need to know if i need to change plans to something smaller. thanks
    No its not stock height!
    1998 GMC "TOY"
    2005 Chevy 2500HD "DAILY"
    Registered User Litljay's Avatar
    Mar 2002
    Central Cali
    I would guess that your lights are gonna dim when you push the system hard. Your battery will last as long as you're not running your system at full tilt with the engine off for extended periods of time.
    It is always a good idea to upgrade the big 3 wires (Bat to starter, bat to alternator, and ground) to a larger gauge. It will NOT solve a dimming problem, but will help.
    I'd say you can get by...
    Jul 2003
    Huskerland
    If your lights dim, get a 1 farad capacitor.
    2004 Chevy Trailblazer
    Completely stock!!! (for now)
    Mar 2002
    Central Cali
    band aid for something that needs an ambulance. No offense, but I truely don't think caps are worth a dollar.
    i had to change it juztyn's Avatar
    Jul 2003
    Georgia
    ask ynot - hes got that amp on 2 12 l5's with stock alternator i believe.
    1997 Chevy RCSB 305 4l60e Bright Red for sale!!
    1998 GMC RCSB 262 4l60e White Next Project Truck
    Registered User Jeff's Avatar
    Sep 2002
    Texas
    My lights would dim pretty bad when I had a JBL 600.1 and a 80.4. I think my alt. (factory) is similar in output to yours.
    '00 Sierra SLT
    Ext. Cab Z71
    5.3L & Locking 3.73
    Oct 2003
    sallisaw OK
    i had a 2000 watt fosgate custom built system in my truck with 3 optimas batteries on a stock 100 amp alt.
    a cap will certainly help with lights dimming, it will also make more of an steady drain on the batts and electrical system instead of the bass amp always pulling the surges off the batts.
    you will find caps in almost every appliance that has a compressor in it. refrigerators/air conditioners, if they didnt help feed that surge of power then they wouldnt be around.
    1 farad is what i ran with great success.
    Registered User Arctic_Scrap's Avatar
    Apr 2003
    Duluth, MN
    I ran a 1200 watt amp of a stock alternator in a 89 chev, only time the lights dimmed was when the truck was off.
    No more FSC.
    1993 Jeep Wranger, 5in lift 33s
    2002 doge stratus
    Oct 2003
    sallisaw OK
    also i forgot to mention the reason for the 3 batteries was i also had a 5000 watt inverter, and a 8000 pnd winch.
    1990 454SS
    Sep 2003
    Bellingham, MA
    I have 2 Logic 3000watt 10's EX1000's
    powered by a BOSS Powerdrive 3000watt amp.
    I run off 2 gauge power and ground, i killed my stock battery, which was a huge diehard. I defintely recommend grabbing an Optima yellowtop.
    Feb 2002
    Tulsa
    Is the 600.1 pushing a 1 ohm load by any chance? Mine would dim pushing 1 ohm, but they barely dim at 2. On the other hand, I'm getting a 1200.1 next week, I may have more of a problem then.
    Sep 2002
    Texas
    I had it running at 2 ohms. I would think the draw would be the same at 2 or 1, since the output is the same. That's weird. I had the 80.4 running at 4ch, 4 ohm each. That was with the factory battery, which I have since replaced, and the 600.1 is idle now. No dimming with the 80.4 and an interstate battery as of yet
    '00 Sierra SLT
    Ext. Cab Z71
    5.3L & Locking 3.73
    Feb 2002
    Tulsa
    Trust me, the draw is much more at 1 ohm.
    Registered User Killer B's Avatar
    Jun 2003
    Long Island N.Y.
    i have an alpine head unit (7893 65wattx4) w/ 6cd changer(mp3)/xm radio going to stock speakers front and rear(93 k5 blazer) and to 2 amps-(1)2400watt legacy-to-2 1000watt Koiler subs in a bandpass box. (2) 2200 legacy-to-2 800watt volfenhag subs in a sealed box. it made a big difference when i added a 2 farrad capacator. i`m in the process of adding a second battery, and capacator (for the oncoming dark season!) i`m going to use 00gage wire for power,
