Page 1 of 2 12 LastLast
Results 1 to 20 of 30
1984 K5 Blazer convert to TBI?
This is a discussion on 1984 K5 Blazer convert to TBI? within the C10 Forum forums, part of the General Discussion category; As a lot of ya'll know, I recently picked up, a.k.a. stole a 1984 K5. It has a carb'd 305/700R4 ...
    hucking fates this server FordeatinZ71's Avatar
    Aug 2002
    Slapoutoftown, AL
    As a lot of ya'll know, I recently picked up, a.k.a. stole a 1984 K5. It has a carb'd 305/700R4 combo and honestly runs alright. But it needs a lot of vacuum hoses fixed and the carburetor is worn out.
    On a sadder note, my tRusty 91 K1500 has died. It has a TBI 350 and a good 700R4 (the K5 doesn't have reverse). I love my 91 but as a lot of people have told me the truck is really too far gone to mess with. Its in really rough shape and the K5 is actually in a lot better shape.
    I haven't completely decided to abandon the K1500 but i'm leaning towards it, its a very hard decision for me to make.
    Anyway, what i'm thinking about doing is taking the entire TBI system off the K1500 and putting it on the K5. I figure this will eliminate the carb issue and a lot of the vacuum systems on it. What do ya'll think? I don't really have the money to plop down on a new carb right now and the TBI would improve fuel milage and driveability and would help off road in off-camber situations also.
    Ideas? Tips from people who've done it before? I know basically what's involved but I haven't ever undertaken it myself.
    2004 GMC Sierra SLE Z71 rcsb, 5.3/4L60E/3.73/G80 time bomb...3" lift, tinted 03+ Silverado tails, plasti-dipped 16" wheels (unknown brand), 285/75/16 Thunderer M/T Extremes, Thrush Welded muffler...
    Big Blue
    Jun 2009
    Alamogordo, New Mexico
    Re: 1984 K5 Blazer convert to TBI?
    This should work you'll need the intake tbi setup ecu
    and corresponding wiring and maybe some sensors.
    Vortec 6 ****in' liter V8 85-bowtie's Avatar
    May 2005
    Clarinda, IA
    I took the wiring harness out of a 90 k2500 and put into my 85 c10. It's really not that bad if you know about wiring. The hardest part for me was finding an in line fuel pump that would run it.
    2002 ECLB Silverado 2500HD Duramax
    2003 ECSB Silverado 2500HD 6.0/ 4L80e totalled
    1985 RCSB C10 TBI 350/ 700r4
    Aug 2002
    Slapoutoftown, AL
    which inline did you end up using? i was gonna snag the stock pump out of my K1500...that's what it'd all be coming of of
    May 2005
    Clarinda, IA
    I ended up using a holley blue inline. The 1 problem you will have using the in-tank pump in your k5 is that the gas tank is not baffled for the fuel injection. I finally bought a gas tank, sending unit and pump for an 87 c10.
    Aug 2002
    Slapoutoftown, AL
    well, the Holley Blue pump worked alright though? i didn't think about the baffling...thanks man! that's why i made this thread, i was sure i hadn't thought of everything
    fortplainman
    Guest
    steal the good tranny from your 1500 and sell it off for parts to fund a 350 or a big block for your k5 a small motor like that doesnt belong in a k5 lol.
    Aug 2002
    Slapoutoftown, AL
    yea, thats kind of the plan right now. might already have a sale in the works. i did more research today and it appears i might have the dreaded <cough>2.73 gears<cough> in this one, like my old 83 K1500 had. but this one sure moves a lot better than the K1500 did...even though it has the same motor...
    May 2005
    Clarinda, IA
    Yeah, the holley blue worked fine for me. It's just a little on the loud side. Nothing terrible, but at an idle you could hear it humming. I probably could have quieted it down by insulating it from the frame more but I just went with in tank style. If you go through with the tbi swap I still have the used holley pump around.
    Aug 2002
    Slapoutoftown, AL
    heck yea man, i'll let you know.
    Registered User crossy's son's Avatar
    Jul 2008
    Pennsville, New jersey (southern)
    Does the gear RPO say Gu2??
    oh and If you're interested my dad has a complete TBI conversion kit for OOBS's going on Ebay soon. He parted an OOBS 89 suburban and he labeled EVERYTHING to make it an easy swap with the ecm and all.
    nice project it looks like
    Currently-
    -91 RCLB C1500 silverado 4.3L 5 speed GU4 G80 beater truck
    -91 Dodge 350 4x4 12v Cummins/5spd 384hp/802tq
    SOLD and missed-- 91 RCSB GMC, restored Black on black, 2/4 drop, 17x9 Torq thrusts, built 350tbi, 5 speed w/hurst shifter, 3.42 G80--- Over 400,000 miles on body
    Aug 2002
    Slapoutoftown, AL
    no Brandon, it has the dreaded 2.73's. GQ1...standard axle ratio. back in 1984 the standard axle ratio with the gas-powered K5 was 2.73s...aargh
    bikes cars trucks women vic_V8's Avatar
    Jan 2004
    Dixon IL
    where do you live at? When I get back home the 1/2 axles are coming out of my 84, I'm not sure what they have, but its 3.42 or 3.73s.
    '84 K30, 7" lift, Converting to International Diesel HP 60/14 combo
    '88 GMC Suburban V2500 5" lift 60/14 with 4.10s 5.3 LS swap TH400/NP208
    '94 GMC Suburban K1500 350/4L60e with updated heads, mild upgrades
    '77 Ford F250 High Boy 400/C6/Divored 205 44/60
    Veteran of Afghanistan (Army SSG)
    Aug 2002
    Slapoutoftown, AL
    i'm in Ashdown, AR. my truck will have 1-tons when i can afford them...just have to live with the 1/2 tons while i can. if i get a set of gears cheap i can put those in...
    Huh? jaredself's Avatar
    Jul 2004
    BFE, West Texas
    Be sure to use the distributor from the '91 as well.
    2007 NNBS CC Z71-Magnaflow, K&N CAI, 2.5" level, Cooper 285's
    1999 C2500 Suburban-New L31
    1974 K20 Cheyenne-350/TH350/NP203
    Aug 2002
    Slapoutoftown, AL
    yep, the distributor and alternator...will be using the exhaust manifolds for now until i can get headers...for the O2 sensor...
  17. #17
    Jul 2004
    BFE, West Texas
    I had the same inclination for one of my oobs so I took everything off my parent's '88 burb. So far the parts have been sitting in the same rubbermaid box for about two years. I hope you actually do the swap. Best of luck.
  18. #18
    Aug 2002
    Slapoutoftown, AL
    yea, i really hope to jump into it around the 1st. i'm gonna start stripping the truck probably tomorrow. then on the 1st when i get the stuff i need to buy for it, i will put it all on...i can't wait to get rid of all that vacuum crap.
  19. #19
    Jul 2005
    Euless, Texas
    Quote Originally Posted by FordeatinZ71 View Post
    You will really like the TBI setup on the LE9 305 in your 1984. Just make sure you secure a 305 chip for it. You can even run the stock knock sensor that is in your current 305. This was the first swap on my van. TBI'd LE9 and it made 191 RWHP @ 4,600 and 268 RWTQ @ 3,200. More HP and TQ than the 350 TBI that replaced it made. Stock engine except for a Federal Mogul CS1014R cam, Edelbrock Performer RPM intake and the TBI. Stock manifolds and Y-pipe as well. High flow cat and magnaflow single in/dual out muffler.
    Running the 305 chip, my LE9 engine liked 14.25 psi fuel pressure and 6* advance.
    I swapped the TBI van harness (removed the pins from the firewall connector and put them into my existing connector with no cutting or splicing), fuel lines, and fuel tank.
    1997 G1500, 5.7, 906s 2.02/1.60, GM 395' marine cam, 1.7 RR's, Marine Intake, BBK TB, 85mm MAF, 6.5 aircleaner, Thorley Tri-Ys, Thunderbolt 2.5 cats, Dynomax 22865 muffler, 4L80E, 0411, Hydroboost, 9.5" 14-bolt 3.73s, 8800 GVW front calipers, March 4490 pulleys, AD244 alt, D-Max fan
  20. #20
    I Hate You All, Equally.
    Aug 2006
    Hell, Frozen Over.
    The mid to late 80's carb systems are quite crazy to look at. Especially the CCC (computer controlled carb) systems like on my 88 Caprice.
    I'd take the stuff out of the K1500 for it. Because you're going to need a new motor anyway. based on your story of what happened to it. I usually find longblocks for sale moreso than bare blocks and bottom ends. So it's probably gonna better that way anyway.
    1983 Jimmy Sierra Classic-Future LSX Swap Recipient
    2002 Silverado 2500HD CCSB LT-Daily Driver
    1995 Corsica-Super-Sleeper in Progress
