Results 1 to 20 of 20
86 k10 8 inch lift kit
This is a discussion on 86 k10 8 inch lift kit within the C10 Forum forums, part of the General Discussion category; hey guys i got a 86 chevy k10 halftun longbed, im gonna buy an 8 inch lift kit for it ...
    Dec 2009
    CT
    hey guys i got a 86 chevy k10 halftun longbed, im gonna buy an 8 inch lift kit for it but i have a set of axles out of a 3/4 ton truck. im gonna put those in since theyre greared better and a little tougher. but do i still buy a lift kit for a half ton which i think would be 52 inch springs? or do i buy something different. also i should have to move the perches on the frame i dont think is that correct? thankss
    Real 4x4s' Rust ryan_thompson87's Avatar
    May 2007
    Portage La Prairie, Manitoba, Canada
    Re: 86 k10 8 inch lift kit
    Yes you need the halfton kit. No moving of perches. The axles attach to springs the exact same way as on a 1/2 ton.
    87 K30-355 Vortec TBI/TH350/208/Dana 60/14FF/4.56s/Detroit/37"Bogger/Ult.TBI Mods/XtremeFI FPR vac. reference/EP241 Pump/LS1 Fans
    07 GMC Sierra Classic - 2" Rough Country Full Leveling Kit/285 Duratracs/Gibson Exhaust/10% Tint/Billet Grille
    Not Really Bob
    Jan 2006
    Newark, DE
    Yea, sure. Get 4" lift 52's for the font and 4" lift 56's with a shackle flip for the back. Same exact setup i'm running on my '81. Super flexy and the ride is plush.
    99 Silverado ECSB 4X4, LQ4, Patriot Stg. 2 243's w/ 59cc chambers, TR224-112, Pacesetter LT's, Nelson tune, FLT Lvl 5.5, PI 3400, UD pulley, 160* t-stat, E-fans, 6'' Fabtech lift, 3'' body lift, 37'' XTerrains, 4.56's, 4'' shackle flip 13.3 @ 99mph on 37's or 13.0 @ 101mph on 31's
    Dec 2007
    Oc, Maryland
    bigbob how much did that run you for all the parts? i been loooking and skyjackers 8 inch kit is like 900ish.i been lookin to do the swap like you did and just the leafs alone are close to 800
    74k20
    mild 383 stroker
    8inches on 37in grapplers
    Not Really Bob
    Jan 2006
    Newark, DE
    I bought Superlift springs and they're ~$180 a piece from Summit. Add about $40 for bushings and it comes to $400 a set, like you said. To cut costs you could run stock 56's in the rear with the shackle flip and a small block(2-3"), since you probably don't need all of 8" of lift back there.
    On the front of my truck I used DIY4X's B52 kit($165) but you could save there too by just switching the stock hangers around. Shackles for the front should be $30 or less. You'll also want to get some limiting straps and bumpstops to prevent over-stretching/compressing anything.
    Sooo, I'll just throw some numbers out there
    $400 springs
    $65-180 Shackle flip
    $30 shackles
    $100 u-bolts
    $50 fasteners
    $90 brake lines
    $80 bumpstops/limit straps
    $150 steering correction
    $100 stock 56's
    $40 blocks
    $160 shocks
    Total approx. $1320
    Of course it can be done for more or less, but that just gives you an idea. What all comes in the Skyjacker kit?
    Edit: forgot shocks, lol
    Dec 2007
    Oc, Maryland
    8 Inch Lift Kit with shocks
    Lift Height: 8 inches
    Front Lift: Leaf Springs
    Rear Lift: Rear Lift Blocks W/Add-A-Leaf
    Front & Rear Hydro Hydraulic Shocks W/ Shock Boots
    Includes:Pitman Arm / Steering Arm / Transfer Case Lowering Kit
    Max Tire Size:39 X 12.5
    Wheel Size:15-16 X 10
    Backspace: 3.5 - 4
    Thats all the info on the kit they give you. do thats eem like its worth it or try to collect parts on my own for a 52in swap?
    74k20
    mild 383 stroker
    Registered User Your41Plague12's Avatar
    Jan 2010
    Pittsburgh, PA
    I'd go with the kit, it's a hell of a lot easier than hunting parts down and having to fab a lot of things to make them work correctly.
    Dec 2007
    Oc, Maryland
    thats what i was thinking and im not going to be doing a loit of wheelin just some mud and sand cuz thats all there is on the easternshore. do you know anything about that kit? i was wondering about having to extend my drive shafts too?
    74k20
    mild 383 stroker
    Not Really Bob
    Jan 2006
    Newark, DE
    It's kind of worth it. Wonder how tall the lift blocks are? I bet the add-a-leaves are those short rigid 1/2" pieces of crap too. Guess you can solve those issues with a shackle flip...
    You'll most likely need your front driveshaft extended for the it to remain in safe operating range. CJTatton on ebay has good deals on new driveshafts.
    You'll need some brake lines too...
    Dec 2007
    Oc, Maryland
    i think its supposed to come with some brake lines, ill have to find out forsure before i order i guess. i beleive the owner before me got the rear drive shaft lengthened already for a 6 inch kit but theres only 4 inches on her now
    74k20
    mild 383 stroker
    Sep 2010
    SFV, CA
    If I remember correctly anything above a 6" suspension lift requires more steering corrections too? The max for only doing the minimal drop pitman arm and draglink was 6" I thought?
    It's been a while so I could be off but check into that also just to be safe. I had three mid-80's K10's and K20 and seem to remember something along those lines when I was going to go bigger than a 6" lift.
    Dec 2007
    Oc, Maryland
    i thouhgt the kit came with all that was needed for the steering but im not positive. what all would be need?
    74k20
    mild 383 stroker
    Sep 2010
    SFV, CA
    I'm not totally sure either man. I just seem to remember that above the 6" lift the steering angles are really extreme and it requires more than just the equipment that comes with the kit. I could totally be wrong though. I am positive that around the 10" kit range it is necessary to re-work the steering linkage but not positive about the 8". Just wanted to tell you to check it out because your price could increase substantially if the steering corrections are needed for safety.
    May 2007
    Six inch you need at least a raised steering arm, ideally the steering arm and drop pitman arm, anything higher I wouldn't even bother without going to highsteer.
    FSC SOUTHEAST CHAPTER kirk's Avatar
    Dec 2006
    Douglasville, GA
    Quote Originally Posted by elsurfo10 View Post
    JMO, but I'd do crossover steering for anything bigger than 6" of lift.
    01 SFA 1500: project truck, in pieces again
    87 Jeep Cherokee: trail rig, slowly getting built
    03 Buick LeSabre: fully loaded daily driver
    84 M1009: constantly broken money pit, finally gone
    Dec 2007
    Oc, Maryland
    how hards a cross over to do and about how much?
    74k20
    mild 383 stroker
  17. #17
    Dec 2009
    CT
    thanks guys. but thats a good question about thye crossover steering. whats it take to do it. amd how bacd would it be if i went without doing the crossover steering.
  18. #18
    Dec 2006
    Douglasville, GA
    http://www.offroaddesign.com/catalog...4crossover.htm
    You don't necessarily need to buy that kit, you can buy all the parts separately through different companies, but you'll need everything that kit comes with as well as a 2WD steering box.
  19. #19
    Dec 2007
    Oc, Maryland
    ok thanks kirk. what would happenin if i didnt put crossover steering with that much lift?
    74k20
    mild 383 stroker
  20. #20
    May 2007
    It would steer like a bag of **** and wear out TRE and drag links like crazy.
