Results 1 to 11 of 11
oxidation removal on a black truck...
This is a discussion on oxidation removal on a black truck... within the Detailing forums, part of the General Discussion category; I'm gonna be working on a buddy's 454SS tomorrow. The truck sits a lot outside his house and the paint ...
    Sep 2005
    Henderson KY
    Question oxidation removal on a black truck...
    I'm gonna be working on a buddy's 454SS tomorrow. The truck sits a lot outside his house and the paint on the hood and roof is somewhat oxidized. What do you guys recommend for making the most of what's still there? (He's trying to sell the truck... got in credit card trouble)
    BTW... anyone looking for a low-mileage 454SS ('90), email me.
    -Charlie
    OBDI: Irritating shadetree mechanics since 1985.
    '93 C1500:
    355, 9.5:1, L31 heads, Edelbrock intake/headers, Crower Baja Beast cam, cat-free , Flowmasters, Auburn posi, Holley 670 Street Avenger-Oh, that's right, I replaced my trans just to change to a CARB!!!
    Registered User 95Tahoe's Avatar
    Sep 2005
    Big Rapids, Michigan
    Re: oxidation removal on a black truck...
    Try either a clay bar, or a cleaner waxer with a da buffer. works wonders, and a lot better then by hand. you don't have to worry about burning through the paint cuz you're not using a heavy abrasive. but try that. if you're still not happy, try using a polish with light abrasive, start with hand polishing, then use a da for the bad spots.
    May 2004
    Amarillo, TX
    Claybar it and then use a good paint polish on it. You should be able to find some 3M polishes locally. An orbital buffer would also be of great assistance.
    Zane Oliver
    '09 Sierra Z71 - Black | SLT Package
    '05 Tahoe Z71 - Black | Navigation | Sunroof
    '93 Camaro Z28 - Red | SS Appearance | Bolt-ons
    Fear The Pinapple! Toolman's Avatar
    Feb 2002
    Hawaii
    Word on the clay bar. You should note that there are different grades of clay bar. You should get the fine cutting for a black vehicle. Others might leave scratches.
    Personal Responsibility – GO F'N GET SOME!
    Sep 2005
    Henderson KY
    OK, tried clay bar, finish is nice and smooth, however, the oxidation is still there. I'm pretty sure this is a clearcoated vehicle, unsure if this changes how I should tackle it.
    I tried the 3M fine-cut polish (can't remember the exact name on the bottle) with a little 6" orbital/directional buffer. Didn't put a dent in it. The unoxidized areas are nice and shiny, and silky smooth, but the oxidation is still there. What would be the recommended next step?
    I appreciate the input, guys!
    -Charlie
    '93 C1500:
    Feb 2002
    Hawaii
    My next step would be to wet sand it. Be sure to use a block. If you have not done this before be sure that you understand the process. You can mess up your paint fast if done wrong.
    The issue that you are having might be that the panel has been repainted before.
    USN SAILOR jared1217's Avatar
    Sep 2005
    ju
    I have a similiar problem with my truck so this may help me. Im not in the market to paint the truck. Keep the comments and suggestion comming. PICS TOO!
    Proud to be an AMERICAN, Proud to serve AMERICA, and Proud to be an owner of three AMERICAN PIT BULL TERRIERS.
    www.customgm.com
    1997 2 door Tahoe Z71
    SOLD
    2004 Sierra crew cab
    2/4 drop, denali head lights, esky handle, vho wheels, cal speed headers, BBT
    Sep 2005
    kingston nh
    it sounds to me like the clearcoat has gone dead, if it has a white haze to it, it probably wont come back. i would use a compound on it and then polish and wax.
    Registered User melncal's Avatar
    Dec 2002
    East Bay, SF
    .....with a little 6" orbital/directional buffer. Didn't put a dent in it.
    How long did you work it in for?
    Do you have any pictures? That would help. If it's oxidation then a good medium polish something like Meguiars Dual action cleaner polish, Poorboy's SSR2.5 or even Klasse AIO and Poorboys Pro Polish will cut through it.
    I don't think an orbital has enough power to do the job...unless it's a Porter Cable or DeWalt D/A. I've had good success removing oxidization with Poorboys Pro Polish by hand and PC...it takes some elbow grease by hand but it does work.
    Here is an oxidized hood before and after using Pro Polish by hand:
    Quote Originally Posted by panelbeater
    If it's a 90 then it's most likely single stage paint and doesn't have a clearcoat, so it's oxidation and not clearcoat failure...unless it was repainted.
    If using a polish and black paint is on the pad then it not clearcoated. If no paint is on the pad then it is clearcoated and like panelbeater said, nothing other then repainting will fix it.
    Sep 2005
    kingston nh
    if its the 90 new style it should be clearcoated.
    Dec 2002
    East Bay, SF
    If that is the case, then it's clearcoat failure and nothing less then repaint will fix it.
