Page 1 of 3 123 LastLast
Results 1 to 20 of 41
I kinda want this but scared to jump into it really...
This is a discussion on I kinda want this but scared to jump into it really... within the Detailing forums, part of the General Discussion category; http://www.autogeek.net/porter-cable-meguiars-kit.html I really need something like this to get rid of all the scratches in my paint but I'm scared ...
    5TOCK silverado_lover's Avatar
    May 2009
    Galveston, Texas
    I really need something like this to get rid of all the scratches in my paint but I'm scared of what if this doesn't take them out or what if I totally just fugg up my paint. Thoughts?
    Heres a link to a thread I started a while back about this
    http://www.fullsizechevy.com/forum/s...d.php?t=414847
    '95 C1500, LT's, 3200 stall, and some PCM tweaking
    Quote Originally Posted by Chevy4life11 View Post
    ive got 8 inches and i still wish i had 6 more
    Sep 2007
    Cape Cod, MA
    Re: I kinda want this but scared to jump into it really...
    If I were you, that is precisely the kit I would be asking for with Christmas coming up. That kit has the correct compound and polish to permanently remove those moderate to heavy swirls and the correct type of pads to work with those compounds for that type of paint condition.
    You can't (and I have tried) fugg up that paint with a porter cable and Meguiar's 105. It's pretty much fool proof because if you start to put to much pressure into the pad with the porter cable, it simply clutches and stops spinning so that you can't burn through the paint.
    You're paint is in such dire condition that one quick pass with Meguiar's 105 won't make it flawless. You might have to make several passes and take some time working at it, or even find that you might get better results if you were to wetsand first with 1500 or 2000 grit. That kit is capable of removing 1500 grit wetsand marks so that also a good reason why that kit is a good fit for you.
    May 2009
    Galveston, Texas
    I'm also afraid of some detail noob swirl marks
    Sep 2007
    Cape Cod, MA
    Quote Originally Posted by silverado_lover View Post
    You mean swirls that you might create with the stuff supplied in that kit. Unless you coat your pads with gravel and sand, that's not going to happen. Bad buffer swirls or trails come from bad technique and methods used with the rotary style buffers and wool pads. The porter cable and foam pads, in my experience, can't even begin to scar the paint like that. You should have no worries with that.
    May 2009
    Galveston, Texas
    Now the task of getting my parents to buy that for me...
    Sep 2007
    Cape Cod, MA
    Offer to practice on your paint and apply what you learn there to their rides. You will have enough of that Meguiar's 105/205 to use on and erase years off of their vehicles too and they would be hard pressed to pay less than what that kit costs to have someone else detail their rides. If the investment benefits them, parents tend to respond positively to that sort of thing.
    May 2009
    Galveston, Texas
    Too bad they barely even care about their sleighs
    Formerly SPLC0668 TwoTone93's Avatar
    Dec 2009
    Pittsburg, KS
    I am in the same situation as you, I would absolutly love to have this kit.
    '93 GMC Sierra K1500
    Bowties and Guitars
    Jul 2009
    Crosby TX
    So where would i go to have that done to my truck? Would paying for someone to do it be cheaper?
    6.0 Killer
    lm7 w/ TBSS topend, milled/ported 243's, 92mm tb. yank 3600 stall yukon 4.10:1 gear, assassin tractionbars, eaton locker, hoosier 27" slicks, tr 220/220 dyno tuned by flaco-- 12.92 @ 104 mph 1.67 60ft.- SOLD
    99 T/A WS6 Built Forged Iron block 370 on Spray Tuned by me
    Registered User bobfig's Avatar
    Jun 2008
    Houston, Texas
    mehh i don't like that kit. i rather have the adam's kit more. it may be $80 more but it comes with a couple more things and imo better compounds/polishes.
    http://www.parts-express.com/pe/show...number=300-635
    Quote Originally Posted by GreenVortec View Post
    it would probably be cheaper to pay some one to do it but after the first time it would be more then what it would if you just bought this.
    that's another thing. if you buy one you could do this to your friend's rides if there's is bad and charge them like $75 to do it and get this payed off.
    i would say i would do it but i don't feel like spending 5 hours to wash, clay, buff, and wax/sealant someone else car.
    EDIT: if you dont wanna spend that much i just bought a cheep one from pepboys for $30 and a couple other things and did a good job. it didn't get every scratch out but my paint/body has a lot of dents and chips so i wasn't going to try to hard on it.
    05 Silverado 1500 CCSB - Airaid MIT more to come
    97 c1500 RCSB 4.3L 3" Spintech Pro Street dumped, vette servo, and LS1 fans - SOLD
    Work Hard, Play Harder TheBigBlackHD's Avatar
    Oct 2006
    Central NC
    I want this kit bad!
    ---MY BUILD THREAD---
    non timebo mala
    molon labe
    XBL Gamertag: C Vengence
    Its always somethin Ghostyman25's Avatar
    Jul 2009
    Atlanta,La.
    Did someone try to wash your truck with a brillo pad?
    White 1993,c1500,rcss,--TOTALED 8/20/10
    White 1999 1500 / Rcsb-TOTALED 5/19/11
    May 2009
    Galveston, Texas
    Jun 2008
    Houston, Texas
    Quote Originally Posted by Ghostyman25 View Post
    he is going for that stainless steal look like a DeLorean,
    May 2009
    Galveston, Texas
    Quote Originally Posted by bobfig View Post
    I'm not going for...I haz the stainless steel look
    Jun 2008
    Houston, Texas
  17. #17
    May 2009
    Galveston, Texas
    Headin to bed man...
    Or you can come with me with that face of yours
  18. #18
    Jun 2008
    Houston, Texas
    k ill be there. it will take me 45 min going 95 down 6 to get to ya.
  19. #19
    May 2009
    Galveston, Texas
    I'll be waiting
  20. #20
    Oct 2006
    Central NC
    This just got really really
    *slowly backs out of room and closes door*
    non timebo mala
    molon labe
