Results 1 to 9 of 9
best way to get stains out of carpet?
This is a discussion on best way to get stains out of carpet? within the Detailing forums, part of the General Discussion category; Working on cleaning a 1995 chevy that has some seiorous issues with stains on the carpet, I know it would ...
    Apr 2012
    elkton, MD
    Working on cleaning a 1995 chevy that has some seiorous issues with stains on the carpet, I know it would probably be easier to replace it however i wanted to make sure no one had any ideas first.
    I have used awesome, Awesome carpet cleaner, and oxiclean.
    Registered User SlvrdoHDmax's Avatar
    Aug 2008
    Jackson, Missouri
    Re: best way to get stains out of carpet?
    Try several different cleaners, some water based, and some degreaser. Different types of stains will need different cleaner to remove it. Spray it down really well, scrub with a brush, vacuum it up, and dry with a clean towel. Sometimes using hot water as well as the cleaner will help bring it up better
    aintskeered93 oldred93's Avatar
    Mar 2012
    Northeast, Iowa
    exactly what kinda stains are you tryin to remove?
    Apr 2012
    elkton, MD
    they look to be half dirt, half oil, and some bodily fluids...
    Mar 2012
    Northeast, Iowa
    Quote Originally Posted by CountryBelle View Post
    cant help you there, but the dirt and oil i would proceed as mentioned above
    Registered User Bigredmariner's Avatar
    Oct 2009
    United State of Texas
    The Adam's Carpet & Upholstery Cleaner is probably the best you're gonna find. Many people have wasted money on the other brands and still not gotten the stain out. Then picked up some Adam's and it removed what the others wouldn't.
    Here's a link to the stuff= http://www.adamspolishes.com/p-35-ad...y-cleaner.aspx
    Use the forum discount code FSC and save 10 % off of that and the price becomes $9.85. And if you're not completely satisfied call customer service and get a refund.
    Here's a video;
    Use the code FSC to receive 10% off your next order at www.AdamsPolishes.com
    Apr 2012
    Wisconsin
    blue magic spot and stain lifter worked well for me
    Registered User moogvo's Avatar
    Jul 2006
    Cameron, NC
    I use westley's Bleche-Wite (tire cleaner)... Haven't found a stain it couldn't handle yet! I sprayed the floor with a little water and shot the tire cleaner on it. Let it sit for a few minutes and went after it with a scrub brush. I used a shop vac to clean it up, then hit it with summore water and vac'ed it up again. Looks factory fresh!
    If you are willing to take the carpet out, take it to a coin-op car wash and hit it with the degreaser then shoot it with the high pressure hose. Use the car wash vac to remove excess water and then let it dry in the sun for an afternoon before putting it back in. I have had AWESOME results both ways.
    It made THIS look factory new:
    and this stain was probably YEARS old! I didn't take an "after" because it was getting late and I wanted to put my new seats in.
    Build a man a fire and keep him warm for a day. Set a man on fire and keep him warm for life.
    Chrome Addict NHurless93's Avatar
    Dec 2010
    Geneseo Il
    If they arent too bad Tuff Stuff and a scrub brush will normally do the trick if they are really bad you may want to take the carpet out hit it with some simple green and a brush then hose it off
    1992 RCLB 4x4 5.0 TBI 700r4
    1997 ECSB 4x4 4.3 Vortec 5 Speed
