Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Adhesive removal
This is a discussion on Adhesive removal within the Detailing forums, part of the General Discussion category; So about a month ago i had removed my rubber impact strips on body of my burban. Well the adhesive ...
    Burbanator riveeri1's Avatar
    Apr 2012
    El Paso, TX
    Adhesive removal
    So about a month ago i had removed my rubber impact strips on body of my burban. Well the adhesive stuck to the body. I used gas, i bought adhesive remover, and nothins is seeming to work, Any suggestions. I am going to paint my truck however not at the moment .
    When you see the Burbunator rolling get the F*** out of my way!!!
    Work Hard, Play Harder TheBigBlackHD's Avatar
    Oct 2006
    Central NC
    Re: Adhesive removal
    Have you tried an eraser wheel?
    ---MY BUILD THREAD---
    non timebo mala
    molon labe
    XBL Gamertag: C Vengence
    Registered User daved931's Avatar
    Apr 2008
    Bangor, ME
    x2. I used a 3M eraser wheel that I bought at an auto paint supply store when I did the ones on my Tahoe. I put it in my cordless drill and it took that adhesive off like a champ. Just don't let the surface get too hot. It's good to do a section and then move to a different one and work your way back and forth.
    1999 2 Door Tahoe 4x4 w/ 14 Bolt SF & TruTrac. Corvette servo, Gibson cat-back, custom tune from Black Bear, AD244 alt. upgrade, Z71 skid plates, Escalade cluster, 2" block + 1.5" crank, 285/75R16 SOLD 1/2012
    2008 Silverado 1500 Z71, Borla catback, block and coil spacer
    Apr 2012
    El Paso, TX
    Never heard of it. Ill check it out thanks.
    Nov 2009
    Nova Scotia
    Goo-Gone has always worked for me
    Habitual Troublemaker cancritter's Avatar
    May 2006
    Alberta Canada
    x3
    [Stole/FOUND 13/03/08 :O)
    91GM 4x4 excb 5.7 @ 40 over, Westers,Eld 3704.Lunati Trickflow 195 @1.6 RR,Walpro 190/overbuilt 700r4 /TCS TC,4.10/tru trac,14 blt,Hooker LT,areofilter,Extreme TBI.MSD.AGR still adding
    97/rclb/5.7/westers tune/stock..sold :O(
    70 fury
    Bowtie Lifer Desert Chevies's Avatar
    Apr 2012
    Phoenix, Arizona.
    Quote Originally Posted by damion View Post
    For me too, as well as Bug & Tar remover
    Registered User Quinton23's Avatar
    Mar 2012
    Indiana
    if there is a thick layer of it, you can try to scrape off as much as you can, without scraping the paint. Then use goo-gone. Worked for me!
    Supporting Member
    Aug 2004
    Springfield VA
    credit card and 3m adhesive remover worked for me on several cars
    Chrome Addict NHurless93's Avatar
    Dec 2010
    Geneseo Il
    Quote Originally Posted by tonkadawg View Post
    X2 3M adhesive and decal remover and a credit card or plastic razor blade works great, heard some use diesel fuel but im not sure if i would try it or not
    1992 RCLB 4x4 5.0 TBI 700r4
    1997 ECSB 4x4 4.3 Vortec 5 Speed
    May 2006
    Alberta Canada
    l musta done something wrong becuse that go gone stuff didnt work worth a hoot for me :O(
    70 fury
    Supporting Member
    Aug 2007
    McVeytown,PA
    Eraser wheel always took most of for me. After that I use wd40 or tar and greaser remover that you can get with painting accessories at any parts store or even Walmart.
    95 ecsb 5.7 3" BL, 285's, smoothed interior,headers,AFPR, floor shifter, nnbs tail spoiler
    Audio- Flip up touchscreen D.A. components 2 12" Memphis Ref. Series and much more to come
    Aaron
    Registered User UnderCover W/T's Avatar
    Dec 2010
    Philadelphia
    Goof Off worked well for me
    Registered User JBecker's Avatar
    May 2012
    New Jersey
    Paint thinner works well, can pick it up at almost any general auto parts store. Just don't leave it on for extended periods.
    Jun 2012
    Greenfield,IN
    plastic razor blade and soak the spot in all-sol and whatever doesnt come off with the blade use a sponge and rub over it works great for me
    Jun 2012
    Nashville TN
    Eraser wheel FTW.... I have had luck using basecoat maker before as well..
  17. #17
    Mar 2011
    East Palestine, Ohio
    i wish i'd of know about that eraser wheel, i used goo gone and it took forever
  18. #18
    Registered User j0shimself's Avatar
    Aug 2008
    Austin
    goo gone...i suggest saturating the area and letting it sit for a while. i took off the chevorlet lettering that was on my tail gate. at first i used a hot blow dryer gun(cant remember the name of that thing) and i got rather impatient and i just kind of ripped the letters off and it left some adhesive on the tail gate. i then tried to heat up the adhesive and scrape it off but all it did was burn the adhesive and turn it a yellow brown color. i then read onlin that goo gone worked for removing sticky adhesive. so i basically drenched the area with goo gone and let it sit for an hour a little longer and the sticky residue just kind of slid off, didnt have to scrub much.
    2006 Silverado 1500
    j0shimself
    :fsc:
  19. #19
    Aug 2012
    Oklahoma City, Oklahoma
    Thanks for the tip! I'll try this!
  20. #20
    Jan 2012
    California
    I got some sap on my car and i used some Goof Off, thouugh thats kinda bad for some paints. But my friend used some stuff called One Shot to get paint off my tahoe
