I use 3m swirl remover by hand most of the time, I'll only use it with the buffer if I'm doing a light compound first.
This is a discussion on sirl removal (products and techniques) within the Detailing forums, part of the General Discussion category; i work in a detail shop and our suplier just switched the brand of swirl remover that they carried and ...
i work in a detail shop and our suplier just switched the brand of swirl remover that they carried and the new stuff sucks. so i am wondering what kind of products you guys use and also what techniques you use. we pretty much just put it on by hand and use our dewalt buffer to take it off with a black foam pad. any info would be appreciated.
3M or Meguirs are pretty much what I use.
I use meguires stuff and a porter cable.
3M Finesse works well as does Meguires products and alot of other top of the line products. The key I found was the Porter Cable 7424 random orbit polisher. Works great with a 70ppi and up foam pad. Yellow foam pads are typically 50ppi and green are 60ppi and are used for buffing. Blue pads are typically 70ppi, black are 80ppi, and white are 90ppi and are used for polishing. The higher the ppi the smoother or finer the foam. You need multiple pads for proper results. Finish it up with some good microfiber towels.
2003 GMC 2500HD SLT CC, 16x8 Weld EVO Velocity 8, 285/75/16 Yokahama Geolander AT+, 2" Torsion key Lift, Billet Grille, Billet Antenna, Go Rhino Chrome Wheel to Wheel Bars, HPPIII, K&N FIPK, Escalade Door Handles, 03 Chevy Tail Lights
pics of my truck
