Boost solenoid.
This is a discussion on 1996 GMC 1500 6.5 check engine light within the Duramax Forum forums, part of the General Discussion category; My truck keeps setting code po236 changed vacuum lines boost sensor and vacumm pump. when u step on it it ...
My truck keeps setting code po236 changed vacuum lines boost sensor and vacumm pump. when u step on it it rolls coal wicked why does this light keep coming on? the turbo works then some times it doesnt when the light comes on the turbo stops boosting i cant figure out the problem![]()
Boost solenoid.
1994 K1500 ECSB 6.5/4L80-E
1987 V20 Suburban DRW 6.2/TH400. WIP.
you mean on the turbo?
Remove the vac pump because they have a tendency to seize up. Also remove the stock waste-gate actuator for a mechanical (spring operated) one. You be happier with the more dependable mechanical vs stock setup. Set at 10-12# under full load for boost.
06' Silverado 2500HD 6.6l Duramax
No. It's above the valve cover on the driver side. Being a 1500, there will also be two EGR solenoids there. The boost solenoid is the front most of the three.
I will never put a spring in place of one of the vacuum system on these engines, ever, nor will I ever suggest anyone else do it.
96 gmc 3500 4x4 4dr dually LB7/ALLISON, EFI LIVE,AD II 165,ported intake horn,4"straight pipe,PPE BIV,custom CAI
The stock system is prone to the plastic tubes breaking, vacuum pumps seizing up and blowing belts, solenoids failing and opening the waste gate prematurely resulting in poor performance, thus uttering one reason people under-rate these trucks and want a Cummins or dmax.
Never saw a vacuum pump lock up, usually a failure to pull vacuum , the vacuum system is a very poor design, check all the vacuum tubes and hoses.
