If you are set on a diesel I would go with a cummins for sure. The 6.2 is a very fuel efficient engine but it doesn't have much power. If you can't do any of the work yourself you are looking at a ton of money, I'd imagine 5k atleast.
You would be a lot better off re-gearing your differentials.... Do some research on that, that is the only way to go, even if you had a diesel.
LinkBack URL
About LinkBacks
