Results 1 to 9 of 9
o4.5 D Max ?
This is a discussion on o4.5 D Max ? within the Duramax Forum forums, part of the General Discussion category; Hello. First off I'm new here. I just found this site. I am looking at a truck with this engine. ...
    Sep 2011
    lansing mi
    Unanswered: o4.5 D Max ?
    I am looking at a truck with this engine. Everything is stock on it. What can I expect for fuel economy unloaded and hauling a 10,000 pound 5th wheel? I don't hot rod, but I also don't annoy people behind me with a really slow acceleration. It has 133,000 on it. I've never had a diesel but I'm wanting to switch b/c my 6.0 is killing me is fuel cost. Maybe get 12 mph hwy 10 city with it unloaded. 8 towing if i keep it at 60mph on a flat hwy. 5-6 is more common.
    Thanks
    Ed
    Registered User Jameslleary's Avatar
    Dec 2008
    Patterson, Ca
    Re: o4.5 D Max ?
    As of right now, the only Duramax available in light trucks is the 6.6...from what I could find on GM`s website. 4.5 is just a pipe dream for now.
    1986 K10 Suburban
    350,TBI
    CFM-Tech Super Sucker
    Jet AFPR
    TBI heads
    Comp 12-388-4(260H)cam
    3" Walker quietflow SS exhaust
    Sep 2011
    lansing mi
    Re: o4.5 D Max ?
    I should have been more clear. It is the 6.6 engine. The year is 2004.5 it has the lly injectors that were installed in the later part of 2004.
    Dec 2008
    Patterson, Ca
    Re: o4.5 D Max ?
    Well, I can tell you that you will get better than 5 or 6.....From what I have heard, you may see from the mid to upper teens while towing, and upper teens definitely when not. A lot of guys out here in farm country are running Dmax`s with only 1 mod, and that`s the Walker Big Truck Muffler. It keeps the noise down to acceptable levels, but allows the turbo to spool up quicker, aand just plain makes the truck a little more efficient.
    1986 K10 Suburban
    350,TBI
    Jet AFPR
    TBI heads
    Registered User WillDaBeast69's Avatar
    Mar 2011
    Barrington, IL
    Re: o4.5 D Max ?
    if you put a CAI, exhaust, and a tuner on that you'll get a lot more power and fuel economy
    1998 K1500 RIP
    1996 K1500 mild 5.7, CAI, straight pipes blah blah 6in lift, rancho shocks, 33s, and some other goodies
    likes big ol' trucks
    Feb 2011
    West of Lansing, MI
    Re: o4.5 D Max ?
    Quote Originally Posted by willdabest69 View Post
    if you put an exhaust, and a tuner on that you'll get a lot more power and fuel economy
    fixed
    '03 2500HD Duramax / Allison | Ext. Cab | Alloy H2 wheels | 305/65/17 BFG KM2 400+ HP
    '05 2500HD Duramax / Allison | Reg. Cab | Machined AR 16x8 | 285/75/16 BFG A/T
    -BOSS 8'2" Power V XT
    '03 2500HD 6.0 Vortec / 4L80E | Reg. Cab | W/T Steelies | 265/75/16 BFG A/T
    -Western 8'2" MVP
    Once witty, now bland. DarkCharisma's Avatar
    Aug 2007
    Internets
    Provided Answers: 1
    Re: o4.5 D Max ?
    The truck in my signature is a 2004.5 (LLY) model Duramax. Unloaded I get about 15mpg combined, 70% city (at least), the rest highway. If I go all highway, I can easily get 17-21MPG, depending where I set the cruise, and if there's a headwind.
    I haven't pulled very much weight, but I got 13MPG at 65MPH, towing into a headwind with the AC on (110* ambient) with this load:
    That's two Yamaha Grizzly's, a Yamaha Wolverine and a Yamaha Timberwolf, with fuel, water, food and gear for 3 days, along with bigger tires/wheels and winches on the Grizzly's.
    I really do love my truck. It's powerful, quiet, pulls like a combination of an ox and a quarter-horse. The only problems with this year is the propensity to overheat. I suggest you look into a new mouthpiece (turbo inlet) for this model truck, as it was a factory weak point. I got the Kodiak MP for $90 shipped, took all of 15 minutes to install and did help my temperatures quite a bit. There are also auxiliary radiators available, and you can really use any number of modifications to help with temperatures.
    '04 CTS-V | CS Diff Bushing | ALRADCO | 180* T-stat | Revshift MM's | Revshift TM | BMR Pinion Brace | 245/45R18 BFG Comp-2's
    ''00 MR2 Spyder | 225/45R16 - Rear, 215/40R16 - Front BFG KDW's | 138hp
    I am the master of my fate; I am the captain of my soul.
    98 Chevy Z-71 ksstang's Avatar
    Oct 2004
    Lawrence, Kansas
    Re: o4.5 D Max ?
    I also have a 04.5 Duramax with the LLY. I have CAI, 4" straightpipe off turbo with 5" tip, Programmer, and I'm getting 16-17 around town all day long, and averaging 22-24 on the highway.
    2004 Duramax LLY, Chipped, Straight Piped, Eagle Alloy Wheels, Hankook ATM's
    May 2008
    Troy,Ohio
    Re: o4.5 D Max ?
    I just bought an 04.5 also. 20-21 hwy...btw has anyone experienced this ordeal with running their truck, then having the upper radiator hose suck closed after it cools down?
