Results 1 to 8 of 8
Transmission Pans
This is a discussion on Transmission Pans within the Duramax Forum forums, part of the General Discussion category; I have an Allison (2005-2WD) tranny. I go down to the parts store for a screw on and internal filter. ...
    May 2008
    Troy,Ohio
    Unanswered: Transmission Pans
    I have an Allison (2005-2WD) tranny. I go down to the parts store for a screw on and internal filter. They ask "deep or shallow pan?". Of course they can't give me a dimension. So, from the flange to the pan bottom, what is deep, and what is shallow?
    I'm so much cooler online Mark13's Avatar
    Nov 2006
    Northern, Illinois
    Provided Answers: 1
    Re: Transmission Pans
    If it's the stock pan it's probably the shallow pan. I have an Allison deep pan on mine and it's probably 1.5-2" taller then the stock one.
    2006 Chevy 2500HD
    Boss 9.2 Poly V plow
    Oct 2006
    PA
    AFAIK ,
    All of the Allisons that were in the light duty trucks (2500HD & 3500) were "Shallow" pans , about 1-1/2" tall, Heavy trucks ( buses , 4500 , etc) got the "deep" pans which measured 3-1/2" or so deep .
    If you swap to the "deep" pan the gasket is the same , the internal filter is the only difference .
    NAPA part # 18668 for the shallow pan and 18669 for the deep pan , this is a filter and gasket kit.
    If you want to re use the OEM gasket (which is perfectly fine) , P/N 18662 for the shallow pan and 18663 for the deep pan filter only .
    FWIW , Allison reccomends internal filter replacment at overhaul , replace the external spin on at service interval time , not that i'm saying not to replace the internal but .....
    The external spin on filter is NAPA P/N 7701
    HTH
    TOM
    1994 3500 Dually , 502HT ,264HR ,MPFI
    2006 Forest River 325RGT 5th Wheel
    2001 3500 8.1/Allison , HP tuners , Raylar, etc
    1993 K-3500 "Ex-diesel" , 454/4L80E
    1992 S-10 434 SBC/Tremec
    1984 S-10 Blazer BBC/700R4/205, SAS
    1980 Z-28 454 - 700R4
    1977 Olds 98 Regency 403/700R4
    1970, 71 and 72 GMC
    May 2008
    Troy,Ohio
    Thanks. I would say shallow. I know it's overkill but I bought the truck used. I am going to drain the pan. Change the external filter, add the required amount of Mobil 1 ATF. Then after a week or two, drop the pan, replace the internal, and external filters, and add the required amount of Mobil 1 ATF again.
    Dec 2011
    LAKE CITY, MINNESOTA
    If the Mobil 1 ATF that you plan to use is a full synthetic ATF be warned that if your Allison trans wasn't built for synthetic ATF (pre 2006), you could cause the external seals to leak. A friend of mine put fully synthetic ATF in his 2002 HD w/ Duramax/Allison and the front pump seal started leaking badly after a few months. He took trans out and resealed the front pump but the leak returned a few months later. He then checked with an Allison trans shop and found out that the synthetic ATF tends to cause the seals to break down and leak. GM and Allison have tech bulletin on this and there is tons of info about this on the internet....
    May 2008
    Troy,Ohio
    Thanks everyone. I may have changed my mind on fluid use again. There seems to be a lot of confusion. I have read that Dexron III is the factory fill for light duty trucks. Then there are fluids that meet TES-295 spec, and fluids that meet TES-389. One thing I've also read is that 2005 and earlier are not Dextron VI compatible. I also found out that Mobil 1 synthetic ATF and Mobil Delvac Synthetic ATF are NOT the same. Mobil Delvac IS TS-295 spec, but Mobil 1 ISN'T. As far as Syn vs Petrol based, the are cross compatible. I'm not sure what made your friend's seals leak. I've changed over rear ends, transmissions and engines from petrol based oil to synthetic without issue.
    Can I Hab Some? Koots's Avatar
    Aug 2006
    Happy Valley, Labrador
    Provided Answers: 2
    I was told that Transynd is the best option out there, some synthetic ATFs may be better, I don't know.
    02' Silverado 2500HD CCSB
    -Mostly stock 6.0L for now...
    1983 GMC Jimmy
    -6.2 Diesel/Built TH350
    Jul 2012
    Nebraska
    Nice
