Standard auto? Try putting it in neutral and startig
-Ziggy-
This is a discussion on No power? within the Duramax Forum forums, part of the General Discussion category; The dash lights on my 07' duramax 6.6 lbz won't come on, the truck won't turn over, I jumped the ...
The dash lights on my 07' duramax 6.6 lbz won't come on, the truck won't turn over, I jumped the starter, it'll turn over, but not with the key.... Any ideas?
-Ziggy-
current mods -
Cree reverse light bulbs
Candied tails
Blackbear Tune
Future
Sounds like you blew a fuse somewhere. My guess is you blew the crank fuse, which should be in the interior fuse panel.
02' Silverado 2500HD CCSB
-Mostly stock 6.0L for now...
1983 GMC Jimmy
-6.2 Diesel/Built TH350
I would recommend contacting your local dealer. It may be something as simple as needing a new key. Feel free to contact me with the last eight of your VIN and I can look into this for you as well. Keep me posted either way. Thank you.
Tricia, Chevrolet Customer Service.
check fuses.
87 camaro z28 mostly stock
Another vote for checkin fuses.
Although possible, a bad ignition switch is unlikely
another vote for fuses or maybe a relay. I've never had this happen knock on wood
Turns out, some of the wires rubbed against the driver fender, and split apart, I spliced them back together and used some old 3/4" rubber hose and a few zip ties to prevent it from happening again.
Great power...must be appreciated...
