GM-4, it is made by Borg Warner.
This is a discussion on stock 6.5L turbo name/number within the Duramax Forum forums, part of the General Discussion category; Anyone know what the name/number of the turbo Chevy ran in the 1994 6.5L turbo diesel?...
89 GMC Stepside 2WD 4/6 drop, working on the stroker again!!!
Y2K Chevy K3500 CCLB Dually 6.5, the Black Pearl.
If you are gonna replace the turbo, don't bother sticking with OEM.
They made the turbo too small for the engine, which is great for off-the-line TQ, but is terrible past 2100RPM. Plus, the small turbo equals higher, hotter temps and pressure (Drive pressure) which can hurt the engine in most cases.
Throwing on a used HX35, H1C or HX40 from a Cummins diesel and you will see less drive pressure and more air flow. This will certainly add more serious lungs to the choked down 6.5TD.
02' Silverado 2500HD CCSB
-Mostly stock 6.0L for now...
1983 GMC Jimmy
-6.2 Diesel/Built TH350
