Results 1 to 15 of 15
exhaust brake/retarder opinions
This is a discussion on exhaust brake/retarder opinions within the Duramax Forum forums, part of the General Discussion category; Hey has anyone installed an exhaust brake on a 6.5L or 6.2L? Is it worth getting and does it increase ...
    Trust me, I'm an engineer bigrusty's Avatar
    Jun 2012
    Canada
    Unanswered: exhaust brake/retarder opinions
    Hey has anyone installed an exhaust brake on a 6.5L or 6.2L? Is it worth getting and does it increase fuel consumption?
    Registered User Jmac72's Avatar
    Feb 2012
    Humboldt IL.
    Provided Answers: 3
    Re: exhaust brake/retarder opinions
    I would think it would work.Like a Pac break.It won't use any extra fuel.It is just a butterfly valve in the exhaust.
    87 camaro z28 mostly stock
    Registered User Chevy53's Avatar
    Mar 2012
    Boston MA
    Why do you Need a jake brake.... They only just started putting them in new trucks for a reason not worth the 2000$+ price tag it probably has
    -Ziggy-
    current mods -
    Cree reverse light bulbs
    Candied tails
    Blackbear Tune
    Future
    Jun 2012
    eastern PA
    Quote Originally Posted by Chevy53 View Post
    -Ziggy-
    An exhaust brake and a Jake brake are 2 totally different things.
    likes big ol' trucks
    Feb 2011
    West of Lansing, MI
    Quote Originally Posted by 19trax95 View Post
    but they perform the same function.........
    '03 2500HD Duramax / Allison | Ext. Cab | Alloy H2 wheels | 305/65/17 BFG KM2 400+ HP
    '05 2500HD Duramax / Allison | Reg. Cab | Machined AR 16x8 | 285/75/16 BFG A/T
    -BOSS 8'2" Power V XT
    '03 2500HD 6.0 Vortec / 4L80E | Reg. Cab | W/T Steelies | 265/75/16 BFG A/T
    -Western 8'2" MVP
    Nov 2005
    Lanark, Ontario
    Quote Originally Posted by Diesel Dan LB7 View Post
    That's like saying a diesel and gas engine are the same thing because they perfrom the same function.
    A simple exhaust brake in 6.2/6.5 woudl work fine.
    I'm so much cooler online Mark13's Avatar
    Nov 2006
    Northern, Illinois
    Provided Answers: 1
    Kinda.
    "A compression release engine brake, frequently called a Jake brake or Jacobs brake, is an engine braking mechanism installed on some diesel engines. When activated, it opens exhaust valves in the cylinders after the compression cycle, releasing the compressed air trapped in the cylinders, and slowing the vehicle."
    Where as the pac brake setup is just a flap in the exhaust to hold air back.
    2006 Chevy 2500HD
    Boss 9.2 Poly V plow
    Feb 2011
    West of Lansing, MI
    Quote Originally Posted by Quyonmob View Post
    They do....
    (produce power from fuel to turn a crank shaft)
    Notice the root word in diesel engine and gas engine is engine thats because they both perform the function of an engine.
    Jake brakes and Pac brakes are both engine brakes which funtion to provide deceleration or (braking) action via the engine transmitted through the driveline.
    -Western 8'2" MVP
    Can I Hab Some? Koots's Avatar
    Aug 2006
    Happy Valley, Labrador
    Provided Answers: 2
    They do....
    Being right on a technicality, doesn't mean you are right overall though
    02' Silverado 2500HD CCSB
    -Mostly stock 6.0L for now...
    1983 GMC Jimmy
    -6.2 Diesel/Built TH350
    Jun 2012
    Canada
    so i gather an exhaust brake isn't something people go crazy over. i suppose it helps on preventing wear on the brakes, but they are there for a reason and city driving isn't a good application for it.
    Nov 2005
    Lanark, Ontario
    They do....
    No chit they do the same thing, suck down fuel pump air and spin a crank, does that make them the same thing? No. Fill both your dmaxes up with 87octane unleaded if they are the same as gasser.
    Fugg it, trade your Dmax on a ford ranger, cus they are the same, both trucks.
    Feb 2011
    West of Lansing, MI
    WOW your internet dick must be huge man!!!!
    A guy uses "jake brake" as slang for engine brake, and someone goes "NO THEY R WAY DIFFERENT DUMMY"
    Just pointing out they do essentially the same thing "perform the same function." You could call disk brakes and jake brakes completely different....
    You have almost woman-like skill to twist words "Jake breaks and Pac breaks perform the same funtion" into "Diesel=gas, Ranger=HD, derp derp." All while being pissy and bitchy. Heck if you could handle the stove and washing machine you might make a good wife someday.
    As a parting shot, Ford Rangers and 2500HD Diesels DO perform the same funtions. The Duramax just does iton a larger scale, burning a less volatile band of petroleum distillates.
    -Western 8'2" MVP
    Feb 2011
    West of Lansing, MI
    As a parting shot, Ford Rangers and 2500HD Diesels DO perform the same funtions. The Duramax just does iton a larger scale, burning a less volatile band of petroleum distillates. Also FWIW diesels don't suck down fuel, it's injected
    -Western 8'2" MVP
    Mar 2012
    Boston MA
    Td:rl engine brake or jake brake isn't worth the money on a 6.5 or 6.2 and plus idk about around you but your not allowed to use and engine brake in the city here
    -Ziggy-
    current mods -
    Candied tails
    Blackbear Tune
    Future
    Nov 2005
    Lanark, Ontario
    I'm the the one all bent out of shape being a whiney bitch? May want to re-read the thread, I was just kidding, you're the one that seems to have their back up and spewed a whole bunch of self depricating nonsense.
