Results 1 to 5 of 5
Engine code 33
This is a discussion on Engine code 33 within the Duramax Forum forums, part of the General Discussion category; I was trouble shooting a squeal/screech today. It kicks in a 3000 RPM as soon as the rpm's drop IE ...
    Registered User allsierra123's Avatar
    Jul 2012
    Eastern WA
    Provided Answers: 1
    Unanswered: Engine code 33
    I was trouble shooting a squeal/screech today. It kicks in a 3000 RPM as soon as the rpm's drop IE the tranny shift or I let off the throttle the noise stops. It does it in park or neutral the same as driving. I was unable to isolate it. But when the hood up its pretty loud and high pitched enough to hurt your ears. Then all of the sudden I got a random check engine light. I took it down had them scan it and got a engine code 33 something about the egr valve or low vacuum. Has anyone else had this happen are the two symptoms related or do I have two very different problems?
    95 yukon 6.5
    Jul 2012
    Eastern WA
    Provided Answers: 1
    Update code was gone today no light and it showed nothing in the scanner. Still have the screech going to pull the belt to isolate it.
    Sent from my SGH-T679 using Tapatalk 2
    95 GMC Yukon 2 Door. 6.5 TD pmd relocation 3" exhaust Duramax Cooling upgrades. And Cold air intake.
    Jul 2012
    Eastern WA
    Provided Answers: 1
    Update new belt no screech. Gotta test drive and see if the code comes back.
    Registered User vegaman04's Avatar
    Dec 2006
    Milwaukee, WI
    Re: Engine code 33
    The 6.5l's are know for the vacuum pumps locking up, check into that.
    06' Silverado 2500HD 6.6l Duramax
    Jul 2012
    Eastern WA
    Provided Answers: 1
    It wasn't locked up. Im guessing the belt was slipping.
