Page 1 of 2 12 LastLast
Results 1 to 20 of 24
HID Conversion?
This is a discussion on HID Conversion? within the Exterior Tech forums, part of the General Discussion category; Has anyone done a HID conversion on a NBS Tahoe? I have been looking on eBay and see a lot ...
    Nov 2005
    jacksonville
    HID Conversion?
    Has anyone done a HID conversion on a NBS Tahoe? I have been looking on eBay and see a lot of the HID conversion kits for sale. Also, does anyone have the xenon headlights? Do they really look anywhere near as good as HID's?
    Feb 2004
    Oakville, ON
    Re: HID Conversion?
    Quote Originally Posted by 05tahoelt
    what kind of HID conversion are you wanting? theres a few different routes you can go with this
    you can go with a plug and play kit that will plug right into your stock 9006? plugs, it will come with rebased d2s or d2r bulbs (youll want d2r if your using a reflector based set up which it would be with your stock lights.....but with a setup as this, you will have hot spots where the light will be brighter in some spots and not as bright in others as it is a halogen headlight, you would have this same problem if you use those ebay halogen projectors
    what i did and the best way to go about it, is to retrofit actual HID xenon projectors into your housings, you will be blown away with the difference in output and you will have a nice cutoff/beam pattern coming from the projectors, heres a few pictures of my setup and how the light is actually focused
    the beam cutoff in this picture is a little off from my bulbs being out of position, but you get the basic idea of where i heading with this
    if you want any other info on HIDs/Xenon projectors/retrofitting/ or just a plain hid kit, shoot me an email @ pridefcf@hotmail.com and ill help ya out
    you can also check out www.hidplanet.com theres TONS of info there for all your HID needs
    Dion
    ridin' Double D's cowboyon24's's Avatar
    Jan 2004
    Michigan
    Re: HID Conversion?
    well like the other guy i have HID's too but it is on a OBS like his. but unlike his i didn't waste my time trying to retro fit projectors that ur really not going to need. i just have the regular euro headlights with 10,000K bulbs. mine was a plug and play set up and i couldn't be any happier. i don't know about him but i don't have any "hot spots" in my lights. there is so much light that goes everywhere it don't even matter. i c a hell of a the road in front of me and don't have any problems. my suggestion to u is buy a plug and play kit from e-bay should run u around 300 put it in and walk away. the guy i bought mine from is "xenonpros" on e-bay great product free shipping be there in 2 or 3 days.
    i posted pics of mine in here
    http://www.fullsizechevy.com/forums/...d.php?t=181401
    civic's are like tampons, every p***y has one!
    www.myspace.com/sittinon22s
    www.cardomain.com/id/cowboypimpin
    Feb 2004
    Oakville, ON
    Re: HID Conversion?
    Quote Originally Posted by cowboyon24's
    do you understand that the higher k rating you go, the MORE LIGHT YOU LOSE right? and you do have hotspots, you just dont have anything that actually puts light on the ground to compare
    if your serious about your lighting you will NOT buy any kit over 6000k, even that is pushing it if you want your lights to be actually bright and not just blue
    go do some reading over at www.hidplanet.com and you will see how right i am about this, your 10,000k kit puts barely any light on the ground compared to ANY xenon projector, or even an actual hid reflector based set up
    if you want superior lighting you WILL retrofit projectors, as NO relfector set up will EVER compare to a projector, and choose a 4100k d2s bulb to go with it, not 10,000k....please dont talk about something you dont have much knowledge on, as from your post that seems to be the case
    Registered User BigBlue35's Avatar
    Mar 2005
    West Milford, NJ
    Re: HID Conversion?
    hey guys i have a question. i just got a pair of these halo projectors from my gf. and i think she got them from stylinconcepts.com. now im not sure what i need for these to work? i see you guys talking about plug and plays. what do i need for these babies to work?
    Baja Brigade Dezfan's Avatar
    Sep 2005
    Blythe Ca.
    Re: HID Conversion?
    Has anyone tried the Toshiba HIR bulbs? 75% of the output of HID for 25% of the price at the same wattage!
    06 Z71 Crew. 33x12.50x17 Pro Comp A/T's on Extreme Alloy 137 Beadlock Wheels. Billet Grill. Custom Painted Bow Tie. Escalade Handles. De-Badged. Molding Removed. Autobaun 10 Inch Wolfer In SCS Custom Box. Lanzar 800 Amp. ORU Leveling Kit w/ Bilstien Shocks. 4-6 Inch Lift coming soon!
    Whippled 99bluetahoe's Avatar
    Apr 2004
    Fremont, CA
    Re: HID Conversion?
    Nice work pridefcf. I'm glad to see someone else using HIDs correctly. I used the hella 90mm H9 projectors and retrofitted DS2 bulbs to them. I'm using 4300K osram bulbs and hella ballasts. Here is a pic of the cut-off.
    1999 2Dr Tahoe 4x4 - 5.7L L31 Marine intake w/39lbers, Whippled@8.5psi, A2W Intercooler, Alky, Tunercat, LTs, FLT 4L60E, PI 2800, Belltech drop, MSD6A, Dual 3" x-piped, 9.5" 14bolt w/4.10s & Auburn, hotchkis, efans
    13.911@96.516 mph
    Registered User StylinMike's Avatar
    Nov 2005
    Edmonton, Alberta, Canada
    Re: HID Conversion?
    Quote Originally Posted by BigBlue35
    From what I understand...nothing, your stock bulbs should plug right in.
    Mar 2005
    West Milford, NJ
    Re: HID Conversion?
    are mine gonna look like 99bluetahoe's with the cut off?
    Feb 2004
    Oakville, ON
    Re: HID Conversion?
    Quote Originally Posted by Dezfan
    IMO waste of money, you will NEVER get anywhere close to the output with any halogen bulb of Xenons
    Feb 2004
    Oakville, ON
    Re: HID Conversion?
    Quote Originally Posted by 99bluetahoe
    i remember i talked to you about your retro a long time ago, asking which headlights you used, i retroed from a set of reflectors instead of the halogen projector headlights, im using Valeo ECE H7s out of an audi A4/S4, but im switching and going with a quad system, 4 TSX projectors
    yours is looking good! just need that cutoff sharper
    Feb 2004
    Oakville, ON
    Re: HID Conversion?
    IF you use the headlights your gf bought for you, your output nor cutoff will look right, due to the fact its a halogen projector, mind you SOME halogne projectors work in xenon situations
    for example, both him and I are using halogne based projectors in our housings, you can tell by the H7 for mine and the H9 for his, but these are the few halogen projectores that will work, and im almost 100% that the onees that come in the headlights you have, will make the beam patter look like poo and you will have hotspots like a reflector based set up
    but your more than willing to try it out and see how you like it, after you buy a kit, you can always sell it and go the retrofit route, but if your serious about lighting, you wont waste your time with a kit, as they are compeltely obsolete compared to any HID retro
    Apr 2004
    Fremont, CA
    Re: HID Conversion?
    Yea, I'm going to redo my headlights in a couple of weeks. I just need to adjust the bulb position a little and I should be fine.
    13.911@96.516 mph
    sin
    sin is offline
    Insuffient funds?..again? sin's Avatar
    Apr 2002
    Houston
    Re: HID Conversion?
    Quote Originally Posted by pridefcf
    Unfortunately most people dont realize this. I got the Sylvania Xenarcs a few years ago and I'm very happy with them.
    Just because you're not paranoid doesn't mean that we aren't out to get you.
    My Movies
    IMFKNLO GMCBlack's Avatar
    Jul 2005
    Lafayette, LA.
    Re: HID Conversion?
    pridefcf those lights seem to work great my mom has a little 325ci BMW with stock xenons and they are great
    Feb 2004
    Oakville, ON
    Re: HID Conversion?
    Quote Originally Posted by sin
    i cant stand the ignorance
    im going with a set of the xenarcs for my fogs/drls on the brush gaurd, they have pretty goot output
    "GMCBlack pridefcf those lights seem to work great my mom has a little 325ci BMW with stock xenons and they are great"
    yep, those would be bosch e46 HID projectors, i almost used them for my lights, but went with the valeos instead
    you cant get better than HIDs when it comes to automotive lighting, its all in the selection of projectors you use
  17. #17
    Mar 2005
    West Milford, NJ
    Re: HID Conversion?
    so are you saying the ones from stylinconcepts that i have are gonna burn out from the hot spots?
  18. #18
    Feb 2004
    Oakville, ON
    Re: HID Conversion?
    no no, they will work just fine, they just will not be able to perform anywhere near as good as an actual set of xenon projectors, your output will not be very good and you wont have a sharp cutoff like shown in the pictures above, but of course they will perform better than halogens
    if you do buy a kit, just make sure you buy the right rebased bulb type to fit your housings
    retrofitting is the way to go IMO, but if you want to try the kit before hand, thats up to you....the retro will be slightly more money, and you will have to do some work on the lights to make the projectors fit, but its well worth it in the end, youll have a even spread of light, and a razor sharp cutoff
  19. #19
    i wipe my own ass chevy_ss_383's Avatar
    Apr 2005
    anchorage, AK
    Re: HID Conversion?
    what is all involved in retrofitting a hid setup? ive never heard of doing it that way.
    92 chevy ecsb 4wd
    350 w/ chip, msd digital 6+ w/ coil, electric fans, throttle spacer, raptor level 4 trans w/ 1800 stall, 3.42 auburn pro series, alpine system, smoked taillights, and a totaled (speed dent) pass. door
  20. #20
    Feb 2004
    Oakville, ON
    Re: HID Conversion?
    Quote Originally Posted by chevy_ss_383
    your taking a set of xenon hid projectors, and fitting them into your current housings, pretty much you have to cut the rear of the housing of, and figure out a way to mount the projector inside of it, and then seal it up from the rear
    its not hard, but with our housing being so small, its going to take a little bit of time to get it right, it would be best to practice on a old set of lights if you have them
    then the bulbs and ballasts just hook right up to the harness that you connect to your stock harness
