aren't those the instrctions off of a can of bondo or something?
This is a discussion on Is this right? within the Exterior Tech forums, part of the General Discussion category; Is this even a right way to fix rust? is the rust not just going to continue around the fiberglass ...
Is this even a right way to fix rust? is the rust not just going to continue around the fiberglass till the whole piece falls off??
http://www.a-body.net/tech/rust/
it dont look right theres still rust on the edges, i thought you were supposed to cut all the mrusted metal off and then replace it with new sheet metal
05 F250 4x4 King Ranch
1998 Tahoe 4x4 33" SSR's
SOLD:
*04 F250 4x4 CC 6.0, 6.5" Pro Comp, 37" Kuhmos & 20" Rockstars
*2500HD 4x4 CC LB7, 305 SSR's, MBRP, Quadzilla
*2500HD 4x4 CC 8.1, Ranch Hand
*1500HD 4x4 CC 6" Superlift, 37" SSR's, 16x10s, Flow & Ranch Hand
*Tahoe 4x4 6.5" DC, BL, Boggers
That is a cheap crappy way of doing it. You would be better off replacing the metal and then using body filler. Body filler and mesh is not strong enough. It will crack and fall off. Now if you are going to sell the car it might hold up for 6 months.
Personal Responsibility – GO F'N GET SOME!
