Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 93
LED bulb replacement and hyper flashing - a DIY solution
This is a discussion on LED bulb replacement and hyper flashing - a DIY solution within the Exterior Tech forums, part of the General Discussion category; I had LED's in my stock tails and they weren't near as bright as normal bulbs. I also had a ...
  1. #21
    Registered User hornsfan10609's Avatar
    Aug 2006
    Austin Texas
    Re: LED bulb replacement and hyper flashing - a DIY solution
    I had LED's in my stock tails and they weren't near as bright as normal bulbs. I also had a hyper turn signal, now I have no issues and people actually can tell when I hit the brakes.
    91 RCSB C1500 4.3 4L60 Cash for Clunkered 8/3/09
    09 Ford Mustang Bullitt #5998 Brenspeed Tune, LCAs. 13.35 @104.3
    94 Ford Mustang SVT Cobra ModdedSOLD 9/4/08
  2. #22
    Registered User 01 Suburban LS's Avatar
    Sep 2003
    San Jose, CA
    Quote Originally Posted by hornsfan10609
    Which bulbs did you use? I wouldnt say mine are exactly as bright as the incandescent bulb it replaced, but it can easily be seen during the day in direct sunlight.
    2001 Suburban LS.
    18x10 Eagle 064's, 6" ProComp lift, Ford Keys, 1.5" rear coil spacers, 35x12.5x18 ProComp X-Terrains
    http://www.cardomain.com/ride/2175737
  3. #23
    allergic to mud RollingBowTie01's Avatar
    Jan 2006
    North Bay, CA.
    Quote Originally Posted by 01 Suburban LS
    You missed my point. In the time it took you to stand in line to pay for that flasher. You can have done to the flasher you already have exactly what some Chinese kid being paid $0.10 a week did to the one you bought.
    Looking at your sig picture of your truck, I assume you did most if not all of that stuff yourself. Moding the flasher ranks up there in difficulty with swapping in those clear corner housings.
    i fully understand now what you meant, but i work at a custom shop so all i had to do was dial a number, do some work then pop it in when it came it. as for the other question i got it from napa auto parts, it is an electronic flasher upgrade that i paid 10 bucks for... a bit more then what that lil chinese kid gets paid for makin it but rather simple fix.
    sig by 454ss
    01 silverado/4.8 jet chip/K&N 77 series/throttle body spacer/3/4 belltech drop/20x9.5 boyds wrapped in 295/45/20 Toyos/'05 tails/leds/and more to come.
  4. #24
    Beware The Evil CrankToe LOHRTBT's Avatar
    Oct 2001
    Yukon, Ok
    Can someone tell me the part # for this as I bought an Electronic Flasher tonight and it didnt fix my fast signal. I guess I need a specific one.
  5. #25
    Sep 2003
    San Jose, CA
    Quote Originally Posted by LOHRTBT View Post
    Slightly modify your OEM one. No need to waste money on an electronic one.
    2001 Suburban LS.
  6. #26
    ALL IN BALLS OUT wp silverado's Avatar
    Nov 2007
    savage md
    Quote Originally Posted by RollingBowTie01 View Post
    do you have a part number or can you tell me exactly what you asked for at napa, id like to pick one up tomorrow
  7. #27
    ......................... Atomic's Avatar
    Jun 2005
    Scottsboro/Tuscaloosa, Alabama
    I got the $10 resistors from the12volt or something, works great.
  8. #28
    Jan 2009
    Alaska
    If it ever gets warm here ill probably do that. But on the other hand i have been driving around with a fast flasher for a good amount of time to get used to it.
  9. #29
    Oct 2001
    Yukon, Ok
    I do not want to mod the stock one if the results you got it what to expect. its barely slower than the hyper flash in my opinion.
    I like the standard flash. I have thought about the load equalizers but the fact they get extremely hot worries me....especially when it gets hot as hell in the summer.
    Im having a hard time understanding why some guys are getting replacement flashers and it works, for others not at all?
  10. #30
    FSC Midwest Chapter! DMANbluesfreak's Avatar
    Jun 2009
    Champaign, IL
    I also like the Standard flash and would like to know the part number for the flasher box you got at NAPA.
    I'm not averse to doing this myself, but I don't like the fact that it flashes about 1.5x as fast.
    2001 Z71 Silverado, Ext. Cab, 5.3L V8 - BUILD THREAD
    Spintech Pro-Street, Vette Servo, 3" BL, Rock Sliders, 37" MTRs, Bilstein 5150s
    14B FF w/ Yukon Grizzly Locker, Leaf Sprung Dana 60 HP, NP241
  11. #31
    Get in sit down hang on. SolMan98's Avatar
    Jul 2003
    Dallas, GA
    Since this thread has been revised, I'll ask a question. I had started gathering LED's to swap out. This past weekend I swapped out all the marker lights and tag lights. They don't flash so no issues of course. I already have LED tail assemblies. I have a set of 24 LED front turn/marker/DRL amber bulbs to put in soon. But wondering about the hyperflash. My understanding, the 06 does not use a flasher, but it's in the BCM. Possible for any issues of hyperflash?
    D/D-2006 HHR 1LT 5-Speed.
    1996 Silverado, 5.7, FIPKII, Elect Fans, S/S Headers, Duals, Wait4Me, 4/5 drop on 18" Weld Evo Velosity's. STOLEN ON 9/9/2006
  12. #32
    Jun 2009
    Champaign, IL
    If you do get hyperflash, you can wire in a resistor in parallel with the bulb to fool the BCM into thinking a regular incandescent bulb is in there and working.
  13. #33
    BlkAlanche CrazyFrazy's Avatar
    Mar 2008
    Iowa
    You will have to have a dealer reprogram your BCM to correct the problem. I had to do it for my 08. It costs about $50.
  14. #34
    Jul 2003
    Dallas, GA
    Quote Originally Posted by DMANbluesfreak View Post
    I'll keep that in mind. I might get them in this weekend. Hopeing the resisters are already built in to these, was told they were, but then again,
    EBay.....
    They were cheap at least.
  15. #35
    Oct 2001
    Yukon, Ok
    What about this option...Get a stock bulb and harness for it, and wire it inline behind the grille? Paint it black so no light output....would this work? And if so..how cost effective do you think it would be? I would think you could get a universal socket at the parts store and a bulb. this should avoid the hot in line load equalizers wouldnt it?
  16. #36
    Mar 2008
    Iowa
    I think it would work but it might not be the cleanest way to do it. Not to mention, if the bulb burns out then you have the same problem again. Doing it correct the first time may cost a little more but can save a lot of aggrevation down the road.
  17. #37
    Mar 2008
    Iowa
    You can also find the LED flashers here http://www.superbrightleds.com/cgi-b...rake-turn.html.
  18. #38
    Jun 2009
    Champaign, IL
    Resistors cost about 50 cents each, less depending on how many you buy.
    Wiring up a stock bulb is a waste of money and will most likely burn out more quickly due to lack of ventilation behind the grille.
  19. #39
    Oct 2001
    Yukon, Ok
    Ok, found the relay fix. Its not quite as slow as stock but damn close. Its a Tridon Brand Electronic Flasher that is made for LED's
    part # EP29. I got it at Advance Auto Parts. It was $15.99
    There you go lol.
    BTW those resistors get extremely hot when under use. They will melt plastic fyi.
  20. #40
    Oct 2001
    Yukon, Ok
    You Honestly wanna go with that theory?? That a bulb in the engine bay gets less air than one in a SEALED housing?? Come on now....
