Results 1 to 6 of 6
Reverse Lights as Hazzards?
This is a discussion on Reverse Lights as Hazzards? within the Exterior Tech forums, part of the General Discussion category; Is there a way to make the white reverse lights function as your hazzards? Diodes maybe? I have some hyper ...
    Registered User Scurry's Avatar
    Jun 2005
    Miami
    Is there a way to make the white reverse lights function as your hazzards? Diodes maybe? I have some hyper white bulbs in there that would look sweet doubling as hazzards.
    2005 Silverado CREW CAB, 5.3 V8 3.73 Gears
    Registered User RassyMX's Avatar
    May 2005
    Nebraska
    Re: Reverse Lights as Hazzards?
    Thats a good idea, i wonder the same thing. I have hyper white reverse bulbs as well.
    Original Gold Member 97Silverado's Avatar
    Nov 2001
    Newcastle, Texas
    Yeah but honestly, how often do you use your hazards?
    Much like alcohol, tobacco, and voting there should be an age requirement for computer usage.
    "Drag racing helps me get rid of all my extra cash."
    Team credit card holder and crew chief - "Hot Rod" Heather JD4193 & Holly "Wood" JD4145
    Jun 2005
    Miami
    Quote Originally Posted by 97Silverado
    True...I just like how they look when you click the alarm-off. I was just thinking...it would be kinda cool to blink as hazzards. And when you do use them...they are bright as CRAP!
    claviz13
    Guest
    Quote Originally Posted by Scurry
    Check with the local laws as well. Most places require you to have red or amber hazards in the rear and amber or clear in the front. Strobes would look better in the reverse light location but the law has a say about those too. We can't win.
    Registered User MedicBiker's Avatar
    Oct 2006
    New Hampshire
    Check out http://www.galls.com/style.html?asso...og&style=FS054 . The item you are looking for is called a "Traffic Backer" or "FlashBack". This will alternate your brake lights and reverse lights. Do check local laws on legality of these, though. They may be restricted to only emergency personnel.
    2003 1500HD 4x4 Crew Cab 6.0L
    4L80-E, 3.73
    LT265/75R16 AT
    Lorado Tonneau
