Results 1 to 6 of 6
estimate on shaving tail gate handle
This is a discussion on estimate on shaving tail gate handle within the Exterior Tech forums, part of the General Discussion category; what do yall think is a good deal on getting the tail gate handle on my 95 chevy shaved off ...
    Official Smoke Detector Mr.350's Avatar
    Mar 2006
    La Vernia, Texas
    what do yall think is a good deal on getting the tail gate handle on my 95 chevy shaved off and possible having the same person remove the large Chevrolet banner that goes all the way across? also what all is involved so that i can possibly negotiate with the body man?
    95 transgo shift kit, vette servo, flowmaster, Yukon 4.11's, Detroit TrueTrac, 4" RC lift, 4" blocks, 31x10.5 Mud Brutes, Pioneer system, 383:. dart 165/67cc heads, eagle rotating assembly, 3704 intake manifold, 47mm TB, comp xe249h, TBICHIPS tune, flowtech headers, spintech 6000
    Jer
    Jer is offline
    FSC's Resident Paint Guru Jer's Avatar
    Aug 2002
    In yo kewl-aid, GA
    Re: estimate on shaving tail gate handle
    unbolt the handle from the backside of the gate and undo the clips holding the rods onto the handle, place the template on the back side of the gate, mark and cut the area needed. set the relocator plate in place and drill the needed holes, and screw it down. install handle by connecting the rods again and bolt down handle.
    flip the gate and make a filler piece(if not provided) and weld and do your mud work. prime, block, reprime if needed, block, prep, seal, paint.
    i shave gates and paint em for 300
    "In our darkest hour...we look to the sky. With a silent prayer...BELIEVE God's on our side. In the land where FREEDOM reigns...and where eagles fly."
    Aug 2006
    rochester, ny
    deffinatly not hard... just need to take your time welding.... 300-400 is a good price.... at our shop we do 300 in primer.... and cut yea a deal if were shaving and painting other stuff
    2000 Silverado Dubyagee's Avatar
    Feb 2002
    US
    I did mine on my 93. Not hard to do. The welding was tedious.
    2bad$doesn't growon trees 96thebossgrnchv's Avatar
    Sep 2005
    lafayette, Louisiana
    $40 for the bracket and filler piece, about $120 to get the filler piece welded on and filled, $200 for paint unless you're good friends with a paint and body guy
    latruckscene.net
    98 lsx camaro
    it's not a lowrider!!! 97Bowtie1106's Avatar
    Oct 2005
    North GA/Chattanooga,TN
    do the handle yourself if you can (its really not that hard) and get a shop to paint it.
    2004 Crew Cab 3/6 on Intros
    Bagged 96 rcsb on Intros
    email me at CoreyFloydDesigns@gmail.com for vehicle renderings
