its been used for about a hundred years, the seams on older cars are all done with lead. if you strip them down you can see the difference in the metal. my 73 olds omega was like this. it should be fine. the only drawback, is there will be a learning curve to working with a molten metal rather than a plastic body filler. the up side is you can just keep heating it and moving it around as you need to.
LinkBack URL
About LinkBacks
