Results 1 to 5 of 5
97 OBS Rear Disc Conversion
This is a discussion on 97 OBS Rear Disc Conversion within the Exterior Tech forums, part of the General Discussion category; Has anyone ever done this I believe there is a kit for this to change it from the drum to ...
    LOW YET CLEAN x97chevy's Avatar
    Jun 2002
    DAVIE,FL
    Has anyone ever done this I believe there is a kit for this to change it from the drum to disc is it worth it and where is the kit ? thanks
    97 OBS K&N Intake, Airaid Spacer, Hypertech Programmer, Hypertech Thermostat, Magnaflow muffler, Shift Kit, Full Custom Audio in Progress
    Dune Slut SilveradoLQ9's Avatar
    Feb 2006
    muskegon
    Re: 97 OBS Rear Disc Conversion
    Try the offroad forum there should be plenty of info in there for ya. Use the search bar.
    2006 ECSB L33/Z06cam/Baker Engineering Tune/6-RCX/20 Spys/35 Toyo/Full Detroit/Turbo'd 80e'd 681rwhp
    1998 RCSB S-10 Lm4/Z06 Cam/T-56/Zexel/Caltracs/Baker Engineering Tune/Static 6-6 drop
    deel'n wif it white04's Avatar
    Feb 2007
    Kansas City
    SSBC makes a rear disc kit
    RAGMC ragmc's Avatar
    Dec 2004
    Gilbert Az
    I have the early SSBC kit on my 91 The calipers are off a 85 olds toranado rotters I think they are off a 75 ford ltd but I know of guys running front rotters of the Impala the bracket is just a flat plate and I think you can find them at speeedwaymoters.com
    Jun 2002
    DAVIE,FL
    Thanks guys they got them gonna order
