Results 1 to 4 of 4
what is the weight of stock 16" 6 lug K1500 alloy rims
This is a discussion on what is the weight of stock 16" 6 lug K1500 alloy rims within the Exterior Tech forums, part of the General Discussion category; What would the OEM rims weigh on my 1991 K1500? I asked a question about tire size and MPG, someone ...
    May 2007
    St. Albans, WV
    What is the weight of stock 16" 6 lug K1500 alloy rims?
    I asked a question about tire size and MPG, someone said something about the weight of the tire having an effect on the MPG.
    So I am wanting to compare the weight of OEM alloy rims V/S aftermarket.
    Thanks Jeff.
    2004 Z71 5.3L CCSSB 3.73's 265/70/17's
    :fsc:
    May 2007
    St. Albans, WV
    Re: what is the weight of stock 16" 6 lug K1500 alloy rims
    Admin, Mods, Sorry about the double post.
    I didn’t think the first post went thru, I stopped it but I guess it posted any way.
    Would someone please delete one of them?
    Thanks Jeff.
    :fsc:
    May 2007
    St. Albans, WV
    Ok after some more searching I found a site that sells used rims and they are listing the weight of the OEM alloy rim at 19 lb.
    The aftermarket rims I was looking at are 25 lb.
    Just thought I would post what I found out.
    Jeff.
    :fsc:
    Registered User UnderCover W/T's Avatar
    Dec 2010
    Philadelphia
    The weight of the stock steel wheels on an 89 k1500 is 26lbs. So you'd b 4lbs lighter than if you had steelies...
