Page 1 of 2 12 LastLast
Results 1 to 20 of 24
99-02 to 03-06 Chevy front end conversion
This is a discussion on 99-02 to 03-06 Chevy front end conversion within the Exterior Tech forums, part of the General Discussion category; I've searched and am unsatisfied with the results, can someone direct me or give me a for sure answer to ...
    Mmmm... layinlow_11's Avatar
    Dec 2004
    Tucson
    I've searched and am unsatisfied with the results, can someone direct me or give me a for sure answer to this. I have a 2002 1500 2wd silverado and want to put an 03-06 front on it. Exactly what parts are needed to do this? I currently have a hood, fenders, headlights, turn signals and grille shell. Is there headlight buckets i need? or the newer core support? i've read a lot of different things, can someone help clear this up. thanks.
    Jun 2008
    ma
    Re: 99-02 to 03-06 Chevy front end conversion
    stylin concepts have the kit
    Registered User lowbotie's Avatar
    Feb 2005
    fresno
    here's a link to the thread i started and the answers i got....
    http://www.fullsizechevy.com/forums/...-end-swap.html
    Dec 2004
    Tucson
    Quote Originally Posted by lowbotie View Post
    Did you do the conversion?
    Dec 2004
    Tucson
    Quote Originally Posted by mikesec View Post
    I searched stylin and couldn't find an 03-06 update kit, just escalade, retro kits and a land rover kit. Can u post a link to it?
    Jun 2008
    ma
    Quote Originally Posted by layinlow_11 View Post
    u need to call them directly
    Feb 2005
    fresno
    no, i hit a snag and couldn't get the hood and fenders. i did pick up everything else, so as soon as extra cash comes in i will get the rest of the parts and do it.
    GM Service Technician mikeyman's Avatar
    Aug 2005
    Bedford, Tx
    headlamp supports for sure, i think the core support is the same. you have the right idea, I might be wrong but i'm not sure the harnesses are the same. may want to check on that, it would be easy to convert if they are not.
    '99 RCSB 2wd -7" front, 5" Rear, 315/75/16 M/T, F/R bumpers, 9" Lighting
    FOR SALE: OEM Camper Mirrors, Tough Country Front bumper,
    Spare Tire Mount, & Skid Plate for 7" pro comp lift (PM ME)
    Dec 2004
    Tucson
    so I went outside tonight and pulled the headlights, turn signals and grille shell off my 02 silvy, when I test fit the 03-06 shell and headlights, the headlight mounting panels don't line up to the grille shell clips. I found the headlight mounting panels on ebay for $30, hopefully thats all thats needed for the new shell to clip on. I will do a write up on this when I get all the parts, maybe it can be stickied and we won't have all these questions.
    NBS Owner IwannaSS's Avatar
    Sep 2005
    Covington, TN
    sounds like a great idea man! i am interested in doin the swap some day
    2005 Chevy Trailblazer 2wd LS White. Tint, painted mirror caps, system, more to come...
    rollin the nasty D's!!! Double Dueces's Avatar
    Apr 2006
    Minnesota
    Grab everything! Hood, fenders, grille, bumper, headlights, might need the header panel, and grab the wiring too. There ya go, thats about it. Just too much $$$ for me, otherwise I'd to it too!
    '01 XCSB a few mods done to it.
    truck parts http://www.supermotors.net/vehicles/...ry/10422/66312
    Dec 2004
    Tucson
    Quote Originally Posted by Double Dueces View Post
    what is a header panel? And Yes, I have the hood, fenders, grille shell, headlights, turn signals, I'm building my own bumper and you need the headlight mount panels for both sides. All I need is the headlight panels, they've been ordered and I can start.
    Dec 2004
    Tucson
    I just did the grille, headlight, fender and hood swap. I didn't do a bumper because i'm building my own. The only part needed besides the obvious is the headlight brackets. They bolt directly to the 99-02 core support. You don't need wiring for anything or a core support. Here are some pics:
    Cognito Lift comming soon
    Nov 2005
    Conroe, TX
    looks good!! thinkin bout doin the 06 chevy or GMC on mine, but not sure
    2001 Z71
    Registered User CamaroRacing's Avatar
    Apr 2004
    Knoxville, TN
    What would besides hood, grill, fenders, and lights for '04 Silverado swap to a GMC.
    Dec 2004
    Tucson
    Quote Originally Posted by CamaroRacing View Post
    no idea, don't have access to a gmc. I think theres more to it tho.
  17. #17
    Apr 2004
    Knoxville, TN
    I was looking at the diagrams on LMC Truck, and it seems the mount similiar, I'm just curious if I took all the chevy parts off, would the GMC parts bolt right up, or would I need new brackets. Swap looks awesome by the way.
  18. #18
    Dec 2004
    Tucson
    really the only difference there could be is the core support, so if you went to or called a dealership and cross-reference the core supports between the gmc and chevy front and see if they are the same or different. That might at least give you an idea if it'll work. Thanks for the comments.
  19. #19
    Jul 2009
    maryland
    layinlow new front end looks good. i just got done doing the same thing 00 silverado with 05 front end.
    camaroracing- the gm front end is alittle different i think you will need a new rad support or headlight mounting brackets
  20. #20
    Sep 2004
    Dallas , Tx
    so did you get the headlight brackets? And did they bolt right up? I have a 2000 sierra and want to do this swap
