Results 1 to 5 of 5
1500 hd extendable mirrors on z71 1500?
This is a discussion on 1500 hd extendable mirrors on z71 1500? within the Exterior Tech forums, part of the General Discussion category; I really wanna get some extendable mirrors on my lifted 2000 1500 and was wondering if the 2500 or 1500hd ...
    Sep 2009
    MINNESOTA
    I really wanna get some extendable mirrors on my lifted 2000 1500 and was wondering if the 2500 or 1500hd mirrors will fit on my 2000 z71?
    kinda like these:
    http://www.1aauto.com/1A/Mirrors/GMC...opping.com_cut
    do the 2003 have the same mirror mounting as my 2000?
    NEW 2004 Sierra D-MAX
    Mar 2008
    WISCONSIN
    Re: 1500 hd extendable mirrors on z71 1500?
    The mirrors will transfer from NBS 03-06 (07 classic) to NBS 99-02, --> But, the wiring is different. You are going to have to make your own splices and match the wiring up. I think on ebay they sell these mirrors but have different plugs made just for nbs 99-02. Check around.
    Registered User 1CLNY2K's Avatar
    Feb 2007
    New Freedom, PA
    As long as you buy a mirror that has the same functions as your current mirrors it will bolt and plug right up.
    -Justin
    2006 Tahoe Z71/5.3/RC leveling kit/18x9 Pro Comp 7036 w/275-70-18 TOYO MT's
    1978 F150 SCSB 4WD/4.9/NV435/NP205/D44/9" locked/4" lift/33" BFG's
    Registered User luisg48's Avatar
    Jul 2007
    Victorville, CA
    the mirror mounting will bolt right up, but the connectors are completely different, i did this swap to my truck which is an 02 1500, and what i ended up doing was going to the local junkyard and cutting the wiring pigtails off the mirrors of a 00-02 truck and just splicing them together, i used this post, http://www.fullsizechevy.com/showthr...it-Information, the wiring colors werent exactly the same but they're all in the same locations, and then to wire in the turn signals i used this, http://www.kwmuth.com/techsupport/pdfs/21000150.pdf, and everything worked
    Feb 2007
    New Freedom, PA
    Thats why I was saying if he only wants electric mirrors and gets only electric ones then there is no need to splice. I have a mirror off of a 2005 escalade that i plugged into my 2000 and just the electric worked cuz thats all that was in my harness. If he wants defrost and signals then yes there is some work to do.
    -Justin
