Results 1 to 9 of 9
6 HI mod done
This is a discussion on 6 HI mod done within the Exterior Tech forums, part of the General Discussion category; Just got this done tonight. This is how I wired it in: Pin 85 on HB to Pin 85 on ...
    Registered User oktain's Avatar
    Jan 2011
    Sudbury, ON, Canada
    6 HI mod done
    Pin 85 on HB to Pin 85 on Fog with 1n4004 diode.
    Pin 85 on Fog to Pin 85 on LB hard wired.
    Whenever my headlights come on (LB's) my fogs come on too. I was always turning them on anyway lol.
    | 2006 Sierra RCSB Z71 | 5.3L | K&N FIPK | Magnaflow CBE |
    | Denali Projectors | Clear park lamps | Switchback LED's | AR Mainline 18x8.5 |
    | DDM 5000k's on the way |
    Luke GMCTruck21's Avatar
    Apr 2011
    Interwebs
    Re: 6 HI mod done
    is there a way to jump the pins under the hood for just the 4-hi mod?
    I would rather do this than wire a ground under the hood.
    2002 GMC Sierra. ECSB. 5.3 LM7. 4L60E
    totaled 11/25/2012. R.I.P.
    Jan 2011
    Sudbury, ON, Canada
    Re: 6 HI mod done
    Not sure. Method for the 06 is different than the 02.
    However had I ran the diode from the HB relay to the LBrelay and left the fog relay out of the equation then I would have had a hi 4
    FSC Midwest Chapter! DMANbluesfreak's Avatar
    Jun 2009
    Elmhurst, IL
    Re: 6 HI mod done
    Quote Originally Posted by Lukeizzle21 View Post
    Oh man its super easy. You just need to ground the ground wire for the low beams I'm pretty sure (may be highs, I'll look into it) and thats it. You can do it under the fuse box actually, let me find the write up.
    2001 Z71 Silverado, Ext. Cab, 5.3L V8 - BUILD THREAD
    Spintech Pro-Street, Vette Servo, 3" BL, Rock Sliders, 37" MTRs, Bilstein 5150s
    14B FF w/ Yukon Grizzly Locker, Leaf Sprung Dana 60 HP, NP241
    the sea hates a coward rebelbowtie's Avatar
    Aug 2003
    Re: 6 HI mod done
    i always wanted 6 Hi….
    Jun 2009
    Elmhurst, IL
    Re: 6 HI mod done
    Well, damn I can't find the instructions for the 99-02 trucks but its super easy so do some searching and you'll be able to find it. No diodes needed or anything.
    Jan 2011
    Sudbury, ON, Canada
    Re: 6 HI mod done
    I actually had a bitch of a time finding the NBS write up here. It's such an easy and common mod I think the thread should be stickied
    Jun 2009
    Elmhurst, IL
    Re: 6 HI mod done
    The 99-02 trucks are different than the 03-07Classic Trucks though...
    God bless the bowtie Croz's Avatar
    Aug 2009
    Green Bay, Wisconsin
    Re: 6 HI mod done
    To do the 99-02 trucks it really simple, all you need is a piece of wire, a wire tape and an eyelet. Pop the hood and find the yellow wire running to your headlights, tap into the yellow wire and bolt it to something metal. I used the fender support bracket bolt, it grounds the headlights and lets you lows stay on when you hit the switch.
    2010 Silverado Ext Cab- No mods yet
    2000 Silvy RCLB, RC Leveling Kit, 285 Grabber AT2's Toolbox, Tonneau cover, tinted tails, magnaflow duals.(sold)
    2005 Suzuki Gsxr 600 modded(sold)
    ^^^Thanks Chuggs^^^
