Results 1 to 17 of 17
Rhinoliner on the Outside of the Truck?
This is a discussion on Rhinoliner on the Outside of the Truck? within the Exterior Tech forums, part of the General Discussion category; What do yall think about doing Rhinoliner on the outside of the truck. I would be doing it from the ...
    Registered User JBecker's Avatar
    May 2012
    New Jersey
    What do yall think about doing Rhinoliner on the outside of the truck. I would be doing it from the lower bodyline down. So i would do the trim, bumpers and probably flares. Or I would do just the paint and leave the trim, bumpers and flares alone, which might look less cheesy. There are a good amount of pretty serious scratches below this bodyline and it would probably be pretty tough to match the paint if I just resprayed black. Thanks in advance.
    Trucks & Gunz PA.REDNECK's Avatar
    May 2012
    Southern PA
    Re: Rhinoliner on the Outside of the Truck?
    I'v seen it done both ways, on the trim, bumpers and flares and just below the trim. Personally I like it below but not covering the trim. I would defenatly leave the trim and bumpers alone or else it would look trashy because there would be nothing to off set the color of the truck, it would all be black. As for the flares it really makes no difference, the color would remain the same so the only real difference there is the texture, the flares won't rust like the body becuse they are only plastic so its all apperance and wouldent really do anything
    Joe
    Joe is offline
    MichiganClassics.com Joe's Avatar
    Sep 2001
    Detroit
    If you offroad often and want the protection, go for it. If you don't it will just look like chit
    I Hate Imports.
    Sep 2006
    Michigan
    http://www.fullsizechevy.com/forum/i...-progress.html
    This is Herculiner, trim/moulding removed, and over the flares. You'll definately want to do the flares too, the texture change would stand out like a sore thumb.
    '01 Silverado. 9.5" FTS, 3"BL, 38x15.5 Kuhmo, 18x10 XD. '06 front clip, HD hood, much more.
    May 2012
    New Jersey
    Quote Originally Posted by Detroit Muscle View Post
    Well that looks pretty damn good. Thank you for the link! I may lose the flares, herculine/rhinoline from the body line down, the plastic pieces on the bumper and trim but leave the chrome for contrast, and then do the bed while I'm at it.
    Did you have to strip the paint completely or just scuff it?
    I Hate Imports.
    Sep 2006
    Michigan
    I just scuffed it up. I used a mixture of scotch brite pads, and an orbital. It really doesnt matter as long as you rough it up so the Herc has something to grab on to. I also wiped it down with Acetone, twice, just for good measure.
    May 2012
    New Jersey
    Awesome, thanks for the help man.
    Registered User TBRays98's Avatar
    Jun 2011
    Fort Myers, Florida
    I did it to my truck it looks cool but its hard to maintain
    And would be even harder for you with a black truck
    1995 5.7L C2500, 4.5" Fabtech spindle lift with 1.5" coil spacer
    On 33 inch Mickey Thompson Baja ATZs with Pro Comp wheels
    4.11 gears with a Detroit TrueTrac LSD
    May 2012
    New Jersey
    Yeah that's what I'm starting to think. And the flat black and gloss black might look a little cheap. Might go to a body shop and get a quote on how much to buff/pull dents/fix scratches on the whole truck.
    Jun 2011
    Fort Myers, Florida
    Quote Originally Posted by JBecker View Post
    Well the herculiner goes on pretty thick it covers all your dents and scratches, which was the reason i did it haha
    Registered User pantera1430's Avatar
    Aug 2011
    converse
    Let me post 2 more time and i can put up a pic of a tundra Rhino'd
    Aug 2011
    converse
    Here it is. [IMG][/IMG]
    Supporting Member
    Aug 2007
    McVeytown,PA
    I did herculiner around 2-3 years ago. I would not recommend herculiner. I followed directions exactly. About a year in I redid and used uv protectant. It didn't help. The top flat parts of flares starts fading first then crumbles off. Then the more you clean which you have to use a brush on the herculiner it crumbles off more over time. My brother in law did his truck at the same time and had it rhinolined and it looks brand new still today.
    For the price herculiner I guess is worth it but if you wash your truck and off road it or even live in a dusty road, you will be redoing it every year. Worst part is of you wax the truck then after first time washing it the residue runs down and streaks through the liner.
    95 ecsb 5.7 3" BL, 285's, smoothed interior,headers,AFPR, floor shifter, nnbs tail spoiler
    Audio- Flip up touchscreen D.A. components 2 12" Memphis Ref. Series and much more to come
    Aaron
    Jun 2011
    Fort Myers, Florida
    Quote Originally Posted by true95w/t View Post
    Dead on ^
    i have to repaint mine once every now and then too, i use two coats glossy black and then tons of uv protection. But once you go offroading its done, you can never completely clean all the dirt off... its great for when rocks hit you or you run over a little kid bc it wont scratch though.
    It only takes me an hour to re paint it so i think its worth it, it just gives it a nice custom look.
    And like true95 said rinoliner is the way to go but its a lot more expensive
    Linex quoted me 1200 if it was already prepped and ready, which is more then my trucks whole paintjob coast me....
    so im sure rino was around the same
    just my 2cents
    Registered User TruckDaddy's Avatar
    Feb 2004
    Texas
    LINE-X Premium (for black) or LINE-X Xtra (for colors other than black) is the way to go. Both hold their color and gloss, both are more durable than Herculiner or even Rhino.
    Pics of entire exteriors with LINE-X. Some pics are not Chevy though.
    Jun 2011
    Fort Myers, Florida
    what does that run?
  17. #17
    May 2012
    New Jersey
    That red Tacoma with the Line-X actually looks pretty decent. Is this similar to Rhinoliner or can you do it yourself? I know how to spray cars and have the equipment and compressors. Just need to be able to buy the chit.
