i would say a tbar crank and a set of 285 70 17 tires
silveradoboy
This is a discussion on Lift/tire help for 03 Silverado within the Exterior Tech forums, part of the General Discussion category; Hey y'all, I've got a 03 extended can silverado Z71, and it needs new tires. I also want to put ...
Hey y'all, I've got a 03 extended can silverado Z71, and it needs new tires. I also want to put a lift on that looks good but isn't too massive. I want A/t tires, and am leanin towards BFGs. Wonderin what you guys think a nice lift would be and what size tire would go good with that
silveradoboy
2006 Chevy Silverado 1500 WT 4.3L v6
2" coil spring spacers/1.5" blocks/265x70x17 wild country sport xht/tsc toolbox/102" whip/cobra 29 cb/si-do glasspack exhaust 45* exits with 3 1/2" tips
http://www.fullsizechevy.com/forum/g...setup-4wd.html
You need to take a look through that thread and decide what looks good to you. This is a very subjective area...what I think looks great will look like crap to others and what I think would be good for a d.d. would be way too high for some and too low for others.
2006 CCSB 1500~Pacesetter LT's and ORY~Borla XR-1/ Spintech 6000~Motive 4:88's~RC Leveling Kit~
315/70/17 Nitto Trail Grapplers, Rough Country Dealer
How much lift does cranking the tbars give
Up to 2-2.5".
Theres no wasting money on bfgs if youre getting the all terrains, you can get an 3" leveling kit and some 33s if thats the direction you wanna go.
Probably a stupid question here, but I'm new to this. What's the difference between lifting and leveling?
Lift=Front and back go up
Level=Front goes up to "LEVEL out" to the rear.
Makes sense. If I went with a 3" level what size tire would be good for that
Stock wheels, aftermarket wheel? Do you want the biggest possible? Are you alright with a little rub? Mine are really wide 315/70/17's.
Right now I've got stock wheels. Tire wise I want one as big as possible without rubbing.
