This is a discussion on New Fuel Lines within the Exterior Tech forums, part of the General Discussion category; Is it possible on a 94 Extended cab, long bed dually, to run flexible fuel hose (stainless braid of course) ...
Is it possible on a 94 Extended cab, long bed dually, to run flexible fuel hose (stainless braid of course) from the fuel filter to the engine compartment?
The reason I ask is that the stock location is located behind the motor, damn near where my distributor is. For appearances, I want the fuel lines to be on the passenger side, where I can mount my fuel pressure gauge and then run from there to my dual TBI units. I was going to use the stock return line tho. It's one piece from the filter to the rear of the engine, and since it's stainless I can't cut it. I know I will have to use alot of clamps holding it to the chassis, and it'll cost alot, but i think it's easier than bending a whole new stainless hard line, and will get my end result that I need.
Thanks in advance
