Results 1 to 3 of 3
Fiberglass Front?
This is a discussion on Fiberglass Front? within the Body Work & Paint Shop forums, part of the Exterior Tech category; I've been thinking about changing the look of my truck and I found this 06 fiberglass front end. http://www.mcneilracinginc.com/off-r...chevy/pick-up/ Has ...
    Registered User stiffy707's Avatar
    Mar 2010
    sonoma, CA
    Fiberglass Front?
    Has anyone tried this out?
    Registered User redchevy914x4's Avatar
    Oct 2007
    Vancouver, Washington
    Re: Fiberglass Front?
    I hope you have a WIDE front end. Those are ment for trucks with long-travel suspension that need the extra clearance of the wide fiberglass. I think they will look retarted if you dont have a wide enough front end.
    1991 K1500 RCLB, 4'' Trailmaster w/pro comp springs & Bilstein 5100's, 315/70R17 Kelly TSR's, Weld Mountain Crushers, 4.56 yukon gears
    Keep working - millions on welfare depend on you
    Mar 2010
    sonoma, CA
    Quote Originally Posted by redchevy914x4 View Post
    I understand what you are saying, I was going to add wheel spacers for the time being until I make enough money to do a custom suspension set up, but for right now I wanted to get that prerunner look.
