Results 1 to 2 of 2
Clear coat on plastic parts
This is a discussion on Clear coat on plastic parts within the Body Work & Paint Shop forums, part of the Exterior Tech category; My clear coat is flaking on my plastic hood scoop. I need to remove it and repaint. Does anybody know ...
    Jun 2005
    Conyers, GA
    My clear coat is flaking on my plastic hood scoop. I need to remove it and repaint. Does anybody know what steps I should take to remove the clear and I guess the paint too? I'm assuming I have to repaint or can I just re-clear?
    Jer
    Jer is offline
    FSC's Resident Paint Guru Jer's Avatar
    Aug 2002
    In yo kewl-aid, GA
    Re: Clear coat on plastic parts
    You can simply reclear, but, if the delamination process has started, you will not be able to do so. you will have to sand the area down with a DA with some 400, prime the area, sand with600, final sand with 800, respray the color and clear. Depending on how rigid the part is, will tell you if you need to add a flex additive to the clear.
    "In our darkest hour...we look to the sky. With a silent prayer...BELIEVE God's on our side. In the land where FREEDOM reigns...and where eagles fly."
