Results 1 to 6 of 6
Need more power.. what to do?
This is a discussion on Need more power.. what to do? within the Interior Tech forums, part of the General Discussion category; I need some kind of more battery power. I have a tv/amp/2tens and i want to be able to watch ...
    Registered User OzzHead's Avatar
    Dec 2003
    Cal
    I need some kind of more battery power. I have a tv/amp/2tens and i want to be able to watch a whole movie without my truck on and not have the battery die.
    Any ideas on the best way to do this?
    Chevy 2001 z71 1500 5.3, 4.56, Flowmaster, K&N Generation II Air Intake Kit and a Tune by JESSEBUBB
    6inch Procomp /3inch PA bodylift / Micky Tompson 16x10 / 37x13x16 Boggers
    member
    Jun 2004
    Cleveland, Ohio
    Re: Need more power.. what to do?
    put in a second battery. I've got two optima's in my truck with a painless wiring dual battery control system. the painless kit is great. with the truck running, both batteries are connected and charging. with the ignition off, one battery is connected to power your stuff, the other is held in reserve. if your main battery dies, flip a switch and it connects the reserve battery so you can start your truck.
    Dec 2003
    Cal
    Sounds like a good idea, is there a website i can get it from? and one maybe showing how to install it?
    Forum Leader nebraskaz71's Avatar
    Aug 2001
    nebraska
    how much is that part?
    No its not stock height!
    1998 GMC "TOY"
    2005 Chevy 2500HD "DAILY"
    member
    Jun 2004
    Cleveland, Ohio
    you should be able to get that kit from any of the performance retailer sites. I think I got it from either Summit Racing of TruckPerformance.com. I don't remember which one. Summit sells the kit for $100. Summit's part number for it is PRF-40102.
    Install isn't that hard. you have to mount a really big relay near the batteries. I put it under the passenger side battery tray on my obs truck. I don't know about the nbs trucks, but mine had a battery tray on both sides of the radiator, so I just put both batteries there. then run a positive wire from each battery to the relay and wire in the control switch. it took me only a few hours to install it, but I'm a complete neat-freak with wiring so it might not take you as long.
    Aug 2001
    nebraska
    I like that idea a lot! Gonna have to check into that.
    1998 GMC "TOY"
