Results 1 to 2 of 2
cruise controll
This is a discussion on cruise controll within the Interior Tech forums, part of the General Discussion category; ok heres the deal when ever i set my cruise it some times doesn't hold. Or when i go up ...
    96TexasZ
    Oct 2004
    Wichita Falls, Texas
    cruise controll
    ok heres the deal when ever i set my cruise it some times doesn't hold. Or when i go up a hill it will just fall and not catch back up. has ne one had this happen to them if so how do i fix it.
    :fsc:
    1996 Chevy K1500,305,Flowmaster
    ,Procomp 6'' suspension, 35'' Buckshot Mudders, 16x10 American Eagle Series 102 24mm offset,Posi-Lok,4.56 Gears
    formerly joker198268 96LoLyfe's Avatar
    Jan 2005
    Texas
    Re: cruise controll
    i had that problem as well, it is your stepper motor gears that is mounted on the firewall behind all the computer **** on the fender. the new stepper motor is kind of pricey, so your best bet would be to go to a junk yard and get one from there.....but mine was doing the same thing. if your driving down the road and you put your cruise on, and your quiet, you can hear the gears are stripped while it is trying to grab.....if you need any other info, just pm me....also, forgot to mention, if you have a 3rd brake light, if any of the bulbs are burnt out, that could be the problem as well, both went bad on mine, so i replaced them all and the stepper motor....
    96 ecsb....40 series dual flowmaster, 3/4 ground force drop, GMC conversion, jl audio stealthbox (looking for passenger side)......ALOT more to come....
