Results 1 to 10 of 10
I Think the motor went on my driver's window
This is a discussion on I Think the motor went on my driver's window within the Interior Tech forums, part of the General Discussion category; On my way home from work, I had my windows open, went to close it and it doesn't go up ...
    Faster then Matty AnniesSS's Avatar
    Jul 2001
    Raleigh, NC
    On my way home from work, I had my windows open, went to close it and it doesn't go up It has done this in the past, but after a couple of minutes, it would go up no problem, not today. I take the door panel off, hubby takes out his multipurpose voltmeter tool and finds that there is power going to the wires, so it must be the motor. (mind you, when I pulled the switch plate off of the door, there was a bit of smoke - figures ) So he takes the cover off the motor and pieces fall out after he removes the motor after he twists it to put the window back up.
    My question is, how difficult is it to replace this motor? I'm really not looking forward to is since it looks like the inner door panel is riveted in place and/or the bolt heads that hold it in place look to be attached to the window itself - is this correct? Anyone have really good detailed instructions before we just dive into it after I get the part?!
    Thanks
    Annie
    1990 454SS Customized
    1989 Suburban Stock as can be
    Quote Originally Posted by BigBoyZ71 View Post
    Impressive. Balls of steel.
    One thing is for sure, you will never see me pissing in your Wheaties. Glad you didn't get bit.
    Quote Originally Posted by BHB View Post
    This truck is gaining mythical RSR status
    Jul 2001
    Raleigh, NC
    Re: I Think the motor went on my driver's window
    No one has any advice for me?
    Annie
    Jan 2004
    garyville,louisiana
    i would like to know also...because my passenger side motor is shot
    88 silverado reg. cab,step side:lowered 3/4",cowl hood.billet grill,smooth front bumper,roll pan,shaved tailgate,bad cover.Engine mods:underdrive pulleys,k&n filter,hooker headers,flowmaster exhaust,and performance chip
    85 astro van:stock,project..soon to be bagged and shaved
    Mar 2005
    TX
    i bought window motor and regulator from CK Resto and replaced both sides. just followed the instructions they sent with it, it was pretty simple. the most time consuming piece was drilling out all the rivets. i replaced mine using bolts instead of rivets in case i ever have to do this again.
    Jul 2001
    Raleigh, NC
    you had to drill out the rivets, huh? Ugh, not looking forward to that, but if it's the only way.... thanks for the heads up
    Annie
    Fear The Pinapple! Toolman's Avatar
    Feb 2002
    Hawaii
    Annie I wish that I had more info for you. It should not be that hard. I would plan taking a day to replace taking your time.
    Personal Responsibility – GO F'N GET SOME!
    Mar 2005
    TX
    it is not that bad really, just the time it takes drilling all the rivets and then getting the right bolts. you'll have to rivet the black control houseing plate or use sheet metal scres for that, bolts are to big and you can't get the control bezel back on.
    Administrator 454ss's Avatar
    Jul 2001
    Staten Island, NY
    I haven't did this in a few years but the complete inner door panel comes out, but you have to have somone holding the window up when you do it, or it will fall down and break....or you can tape it up real good if you're on your own....once the panel is out you have access to it....it's pretty easy after the rivets are drilled out
    click signature for pics
    90 454ss
    92 454ss
    08 Avalanche
    I wish people were like slinkys, fun to play with but when I get bored I can push them down the stairs.
    Home of the Snooki punch! CKTA's Avatar
    Aug 2001
    New Jersey
    Stupid question, but if the window is stuck down........can you still get to all the bolts to loosen the window from the down position?
    2013 Carlisle All Truck Nats info..
    http://www.fullsizechevy.com/forum/o...th-2013-a.html
    Mar 2005
    TX
    yes, mine was stuck down and I had no problems getting everything off...
