Results 1 to 8 of 8
2004 to 1990 Bucket Seats
This is a discussion on 2004 to 1990 Bucket Seats within the Interior Tech forums, part of the General Discussion category; Does anyone know anything of putting a set of power bucket seats from a 2004 silverado into a 1990 silverado. ...
    Registered User CadillacMest96's Avatar
    May 2004
    Michigan
    Does anyone know anything of putting a set of power bucket seats from a 2004 silverado into a 1990 silverado. I realize I do not need seat belts, and I am not concerened of the wiring, but has anyone done this? Do they fit decent? Are the too tall ot too short? Let me know if anyone has any info on this. I have a set of 2004 Dark Charcoal Cloth Buckets. I also Have a 1998 Light Gray Silverado Bench seat with attached center counsole that flips up or down that I will consider selling. Please Help.
    Feb 2005
    east tn
    Re: 2004 to 1990 Bucket Seats
    the size should be OK,see if you can bolt the tracks of your OBS seats on the new ones.
    May 2004
    Michigan
    nope, i had a bench in there stock, they seem to be good size, but i have to cut the floor up and flatten it out and weld studs to my floor. it will be worth it though.
    Jun 2005
    Richmond, Ontario, Canada
    Quote Originally Posted by CadillacMest96
    Same problem I have. I picked up a set of buckets from an '01 for my '88 Silverado. The tunnel has to be flattened out a bit on both sides before I can put them in.
    May 2004
    Michigan
    yeah thats what we are in the process of right now, i will post pics when we are done.
    Registered User denmason's Avatar
    Jul 2005
    Tracy, Ca
    Can't wait to see the pics, I just got a set of 99's for my 88 silverado ext. and sure could use some tips.
    Jul 2005
    Tracy, Ca
    I'm putting some 99's in my 88... whew pita, are you guys pounding the tunnel flat or cuting and welding? I sure could use some tips here.
    Ditch the zero Nick5811's Avatar
    Jun 2005
    San Jose, CA
    pounding/cutting...?
    are you talking about the transmission hump? why is it a problem? are the newer seats taller than the older seats? my old one rested on the trans hump and had two 6" brackets on each end...I solved my problem by putting Jeep Cherokee seats in my 88, but I have been contemplating a 2000+ swap when I find $500 to drop on a new seat.
    Thanks for the clarification
