This is a discussion on Gauges eratic within the Interior Tech forums, part of the General Discussion category; I have a 1986 K2500 4X4 that the gauges moved all over the place, wouldn't stay in one spot, I ...
I have a 1986 K2500 4X4 that the gauges moved all over the place, wouldn't stay in one spot, I replaced these with some others I got from a salvage yard and it seems to have helped but the Temp gauge now when I shut it off goes full hot but as soon as I turn the ignition switch on it falls back to the correct spot. Should I try a different gauge or is this a ground problem???
