Results 1 to 7 of 7
Seat cover removal
This is a discussion on Seat cover removal within the Interior Tech forums, part of the General Discussion category; Well I broke down and bought a set of 97 buckets. My problem is there dirty ( got them cheap ...
    Nov 2004
    Thunder Bay Ontario
    Seat cover removal
    Well I broke down and bought a set of 97 buckets. My problem is there dirty ( got them cheap ) and I want to clean them. I think the best way to clean them would be to remove the stock seat cover and wash it then reinstall it. I cant get the motor bracket of the bottom to get the mounting bracket off the seat to remove the cover.
    And if any one has steps on how to remove all the covers off the seats including arm rests, electronics, head rests ( I knwo theres lots of you out there ) please let me know how to do this. Does anyone knwo where I can find the online katskin install that should tell me how to should it not ?
    Thanks,
    Mike
    95 Silverado RCLB Z71 3/4 ton
    6" ProComp 3" BL
    38x15.50x20 Nitto Mud Grapplers on 20x10 Eagle Alloy 064 Series
    06 LQ9 6.0L, NV3500, 14SF with 4.88's
    True Duals, Mangaflow Dual-in Dual out with 45's
    Supporting Member Bob T's Avatar
    Mar 2004
    Lompoc, CA
    Re: Seat cover removal
    Don't know how remove yours, but WARNING on the machine wash idea. If those things shrink just a little they won't go back on. Ya might try a hand held upholstery shampoo machine first.
    KJ6LFD
    Nov 2004
    Thunder Bay Ontario
    Yah ended up hand cleaning them couldnt get teh bracket off. Turned out nice still wet but very clean. I'll post before and after pics of the install tomorow.
    6" ProComp 3" BL
    Registered User mrteacha's Avatar
    Jul 2005
    ny
    did the 97 seats bolt right up or was there any custom fab work to get em to fit ? i have a 92 fs blazer and can get my hands on a 95 interior for cheap
    1992 2 dr FS Blazer 4x4
    Aggie Class of 2012 mitchellz71's Avatar
    Sep 2005
    austin texas
    try tuff stuff to get out the stains, i used it for the carpet in my truck and it worked great. it comes in a red and yellow can if i rember right.
    '98 ECSB Z71 DC lift with 35 MTZ's and yukon 4.88s Kappa 6.5's and 6x9's PG 600.1 PA LT 960 2 10" Assassins sold
    new truck- '04 Silver CCSB lt z71 5.3l 3.73
    Nov 2005
    Canada
    Stuff in red/yellow can I believe is called "Power Out" by turtle Wax. Stuff works great ! 1) Spary... sit... then wipe off......2) spray...sit... then scrub and vacume out.
    Nov 2004
    Thunder Bay Ontario
    Quote Originally Posted by mrteacha
    Your drivers side seat will fit like a glove but the passenger side has diffent mounting holes o youll have to drill 3 new ones.
    Mine i had to drill a total of 5 new hole... 2 on the driver (becuase it was a bench) and 3 on the passenger side because of the difference in mounting. It is a beautiful upgrade. Only have to do the dash swap and ill have a full new interior :).
    6" ProComp 3" BL
