bump
This is a discussion on Trans temp gauge within the Interior Tech forums, part of the General Discussion category; Has anyone ever added a trans temp guage to a 1/2ton truck?...
2004 Chevy 3500 Duramax Dually 4x4 LT
1997 Chevy Suburban 5.7L 2WD <-- 200K+ miles
2007 Ford F-150 King Ranch 4x4
2008 Lexus IS250
2006 Honda CR-V ELX 4WD
bump
2008 Lexus IS250
put a cluster in ur truck that has one and u should be good to go
'01 1500HD- 6"-8" Fluorescent Green CST Lift w/4" lift spindles...UCA w/Uniballs, Daul Fox Shox, 10" Springs, Eagle 114's,Nitto Mudd Grappler 38/15.5/20,kodiak steps, 2 Kicker 12" CVRs...Goin Big And Bumpin' Along Tha Way...
escalade / ss / denali possibly. the trucks are prewired for them. just put in the cluster and it will all work. if you have a 100 mph speedo and you put in a 120 it will still display your speed correctly, so dont worry about that.
oh, theyre 05s. just forget about the speedo part.
i have a escalade cluster and it comes with the trans temp. at first i wasnt sure if it worked but then i took a little trip and it only read up to about 110. so i wasnt sure if it was workin or not. but i guess it does since someone said its prewired.
