Id go Vinyl...Lay down some foam then stretch vinyl over it. IMO it looks badass ive, seen one or two done like this.
This is a discussion on What to cover my console with? within the Interior Tech forums, part of the General Discussion category; I'm making a center console for my '91 out of plywood. It's pretty much built and fits great but I ...
I'm making a center console for my '91 out of plywood. It's pretty much built and fits great but I don't know how I should cover it. I want a tight fit but I was thinking of using a filler then primer and painting it but I don't know how well that will work since its wood. Or would carpet or vinyl work better?
id go with the vinyl as well
I think vinyl looks cheesy when you put foam under it. It gives that padded 70's kitchen chair kind of look.
I'd smooth it nice with the bondo, and cover it directly with vinyl. Buy good quality heat-stretchable vinyl, and practice on some scrap. With heat, you can do a lot of nice things with vinyl.
If you do decide to paint it, I'd suggest either a skim coat of bondo over all the wood (especially any end grain), or get some fiberglass resin or Sanding Sealer to brush on, then sand smooth. If you don't, you'll use a ton of primer before it stops soaking into the wood.
Whatever you cover/paint it with should be cool, just wanted to let you know about this site i ran across... They seem to have a lot of cool materials for interiors and whatnot, not sure how the pricing is, but it'll show you whats out there. http://www.selectproducts.com/
later on,
Mike
Remember: You can sleep in your ride, but you cant drive your house.
fake fur....make it pink
I like the pink fake fur idea. I've been thinking about that for my interior, JK! I'm in the process of finishing my console. I was going to use an SEM paint to match the texture of parts of my dash, but I went junkyarding the other day and found a new dash to work with. So I am now going to sand smooth parts of the new dash, and then paint those parts and my console so they match.
'99 Tahoe - Whitey
'03 Tahoe - Blackey
