I work on alot of these doors at work. What I found that works good is to get the window down about 3 inches if you can, it makes getting the regulator arms back in slides easier. Leave a couple of the screws on the bottom of the metal panel, pull out on the top gently and remove the clips on the door handle and lock rods. If you have power windows, unhook rod from actuator. Its easier with someone helping you, have them hold the glass, remove the screws on bottom and slide panel back and forth to get it off of the arms. Get a rag or towel, put on rocker panel. You can rest the front of panel on towel and rear of panel on the ground, it will sit there unless maybe your truck is lifted high. You shouldn't need to unhook any wires except for the window motor. Go about replacing the motor as normal. If you have anymore questions let me know.
LinkBack URL
About LinkBacks
