The switch panel should just pop out and then disconnect it. Remove the two screws holding the handle in. The rest of the panel just pops off. You might have to pull the sail panel but it just pops off, too. You will probably snap a couple of the fasteners so I recommend having some on hand just in case. Pull the panle away from the door, disconnect the courtesy light and lift it off. It is really quite simple. Hope this helps.Originally posted by 2drTAHOEz71
Got some JL components I want to put in today, but i cant figure out how to take off the door panel. Im a pro at taking off door panels without power windows, but I cant seem to get mine off. Can anybody help me out?
LinkBack URL
About LinkBacks
Sig By alphaecho4386
