Results 1 to 4 of 4
Headlight switch help 90 to 98 convert
This is a discussion on Headlight switch help 90 to 98 convert within the Interior Tech forums, part of the General Discussion category; Solved, please delete...
    Jan 2007
    Hazleton PA
    Locked and Loaded
    Feb 2006
    Ocala, FL
    Re: Headlight switch help 90 to 98 convert
    I didn't see what you originally wrote, but I am interested in what wires you have going to what. I think when I converted mine I switched up a wire or two. Any insight would be appreciated.
    Selling my 2003 2500HD on 38s and 24s. Auction ends on 12/28, bid now.
    http://cgi.ebay.com/ebaymotors/?cmd=...#ht_653wt_1064
    Jan 2007
    Hazleton PA
    the wire colors all matched with the exception of there being a few left over on the new switch, and there being 2 brown wires on the truck side. My original problem was caused by a wiring screw up in the cluster not the switch. I am still fighting gremlins with the cluster wiring. Finaly got all the other stuff solved though.
    Registered User mrteacha's Avatar
    Jul 2005
    ny
    Quote Originally Posted by TheRookie
    hopefully you could post up the color codes/connections and what got hooked up to what. i have all the parts but havent figured out the wiring so i havent begun.
    1992 2 dr FS Blazer 4x4
