Results 1 to 5 of 5
Painting without sanding?
This is a discussion on Painting without sanding? within the Interior Tech forums, part of the General Discussion category; I've read a lot of the post about painting interior parts. And If you want a textured finish everyone says ...
    Quads and Trucks
    Aug 2005
    Kansas
    I've read a lot of the post about painting interior parts. And If you want a textured finish everyone says just to clean it up, spray some adhesion promoter, and color, and then clear. However in the past when I have painted textured material, like my dash, the paint has just filled in the texturing and it turned out looking like crap. So has anyone painted their dash or trim pieces without sanding or glassing them, and did you use a spray gun, or just spray paint cans?
    Thanks.
    -Engineering Physics student and Fluid-Power system designer-
    99' Z71 Silverado
    08' VortexMax Silverado
    04' Honda 450R
    80' Kawasaki 440
    May 2005
    Naples, Fl or Southampton, Ontario
    Re: Painting without sanding?
    I would like to know the answer to this also. Sanding is a pain.
    Registered User rainman318's Avatar
    Feb 2007
    Louisiana
    Are you tring to paint your dash to match your exterior ?
    Quads and Trucks
    Aug 2005
    Kansas
    yeah
    99' Z71 Silverado
    04' Honda 450R
    80' Kawasaki 440
    Feb 2007
    Louisiana
    If you are painting textured pieces and want to keep them that way you will more than likely need to use a paint gun so you can put it down thin enough to not fill in the texture. If you want smooth with minimal sanding you might try some high build primer first to fill in the texture.
