Results 1 to 8 of 8
Switch Positions and running wire through firewall
This is a discussion on Switch Positions and running wire through firewall within the Interior Tech forums, part of the General Discussion category; I am installing a pair of kc lights on my grille guard and am trying to put the switch somewhere ...
    Apr 2002
    Collierville, Tn
    I am installing a pair of kc lights on my grille guard and am trying to put the switch somewhere I was thinking to the left of the steering wheel so post up your pictures so I can see what ur setup looks like also where are you guys drilling threw the firewall to run the wires
    06 Z71 CREW TINT, AUTO FOGS, HI4. FLOWS, BILLET GILLES, DEEZEE BLACK EURO GUARD W/ 2 150W KC DAYLIGHTERS, DEEZEE LOW PROFILE TOOLBOX, V3 BACKUP CAM, ORD LEVELING KIT W/ BILSTEINS & COGNITO CONTROL ARMS, BULLY DOG TUNER, 35" FIRESTONE DESTINATION MTS, SS GAUGE CLUSTER, HATCHIE BOTTOM SEAT COVERS
    Apr 2002
    Collierville, Tn
    Re: Switch Positions and running wire through firewall
    come yall have to have switches
    king rigger reppin CAF I DjLunchbox's Avatar
    Jul 2003
    manchester, CT
    alot of people choose to run the wires thru an existing hole, for the throttle body cable or the fuse panel. if you drill use a rubber bushing in the new hole to prevent wires chafeing (sp?)
    i hate rust!! 1ugly88's Avatar
    Jun 2005
    Leominster MA
    on my truck i mounted the switch on the right side dash. i drilled the hole through one of the plastic covers that were for the cargo light(i think) that way there if i decide to take em off later i only have to replace that cover instead of the whole dash bezel. i'll post a pic up tonight when i get home if you want.
    May 2007
    NN, VA
    Exclamation Re: Switch Positions and running wire through firewall
    hey guys,
    Pilot makes a wireless controller setup w/relays etc.. for around 20-30$$ no holes or firewalls breached....works good.
    good luck,
    Anthony
    Apr 2002
    Collierville, Tn
    really where can u get this wireless thing
    The Flying Dutchman neevnav's Avatar
    Jan 2007
    Stouffville, Ontario, Canada
    I ran my wires through the existing hole under the passenger side of the dash.
    1994 K1500 350
    K&N Open Element, MSD 6A, Cobalt SS E-fans, BFG A/Ts, Cat-back duals, TSX HID retrofit
    Quote Originally Posted by Jim
    I'm out of state withno Internet. I had to fix the forum with my iPhone. Sorry guys
    Aug 2002
    Cumming, Ga
    on my old '00 chevy i took a coat hanger, stuck it through the gromet where the main harness comes through ont he driver side... taped the wire to the hanger and pulled it through.. worked perfectly fine for me
    Whiskey for my men, beer for my horses
