Results 1 to 3 of 3
Driver door lock/window/light not working after door panel removal
This is a discussion on Driver door lock/window/light not working after door panel removal within the Interior Tech forums, part of the General Discussion category; I searched, but I didn't find a solution, only where a few others had a similar problem, but didn't post ...
    Registered User 05 Z71's Avatar
    Jun 2005
    Va
    I searched, but I didn't find a solution, only where a few others had a similar problem, but didn't post the fix.
    I replaced my handles today with some cool factory body color bezels and chrome handles-easy enough except that my driver door is dead now. The driver's power mirror still works-passenger doesn't, but the light, power lock and window on the driver's door don't. The passenger door works fine using the switch on the pass door-the lock only controls the pass door-driver's is dead.
    I have taken it off 3 times and reconnected everything, checked the fuses I thought affected it, disconnected the battery for a while to reset the computer...I am out of ideas
    05 ECSB Z71, Superlift FIT, 18x10 MT Classic Locks, 35/12.50 Nitto Mud Grapplers
    78 K20, 87 Samurai, 82 Yota 4x4 soon to be SBC, 00 S10 DD
    Registered User greydemon's Avatar
    Sep 2005
    south san francisco, CA
    Re: Driver door lock/window/light not working after door panel removal
    I have the same problem on my 03 only reversed, my passenger door is dead. I've tried everything and have not fixed it yet. Nobody on this forum could help or even people I asked at work. I have dealt with his for a year or two and don't know what to do besides take it to the dealer and see if they can fix it.
    Australian Chevy
    Feb 2006
    Melbourne, Australia
    Have you used a multimeter to check and see if you're actually getting power to the door switches etc. Also check for a decent ground.
    Howard
    YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T
    MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE
    DUCT TAPE.
    98 K1500 Suburban, 4L80E, Whipple SC, Marine Intake, Hydroboost, LS1 0411 PCM.
