use search theres like a million threads on this already...
i think its fairly easy if you have all the peices. i think the hardest part is tracking down every last little part
This is a discussion on 95 dash to a 94 truck? within the Interior Tech forums, part of the General Discussion category; Would it be hard to install the dash from a 95-99 truck into a 94 half ton? I've been pondering ...
Would it be hard to install the dash from a 95-99 truck into a 94 half ton? I've been pondering doing this but i'm not really sure what I would have to do.
1992 black 454 ss -2400 dollar beater dd
1989 jeep cherokee cut 2 door-
cage, 4.56 locked d30 d44, 4.0l aw4 np231, 36x14.5 tsl radials, xrc8 winch, custom bumpers and bodywork, off road machine
1967 baja bug, dp1600, bus portal ends- currently in resto
ha, this is prolly a stupid question...but where is search!? i can't find the darn thing anywhere! or maybe i just havent looked hard enough![]()
top right, right under your private messages...
2007 Corvette Z06 473/432
1996 Chevy Dually Work Horse
ha, i found it as soon as i said that. was lookin for a search bar, not the actual word "search". thanks though
haha maybe they should make a sticku on how to use search
that would have saved me ALOT of "searchin"! hahaha, bad joke i know!![]()
There are a few threads on it. None of them all that great, IMO. Im currently gathering parts to do the swap in my truck. Have most of them so far. Gonna take a ton of pics and document the process.
- 1993 C1500 - 5.3L/4L60E Swap - 3/5 Hotchkis - '96 Interior - Tuned by EPS -
- 2012 Camaro V6 1LT - Victory Red -
It's fairly straight forward. The brackets for the steering column need to be swapped and some holes in the firewall are slightly different.
Sweet, i did a search to find some threads and i agree they arent too great but i'll be looking forward to yours.Originally Posted by SimpleGreen
I have my entire dash, repainted and all. Wednesday Im going to pick up door panels and some other items. Then Im gonna order door handles, sound deadening, and some other stuff. Im also devising a plan to mount the old digital controls comfortably into the new dash.Originally Posted by ddawgnd
Are you planning on doing the whole interior or are you just doing the dash? I saw this carpet on the internet that supposedly has the sound deadening material built in the middle of the carpet and whatevers on the bottom of it.
I assume yours is a 94 or lower? Do you know how well the 95 and up door panels fit the curves of the door?
Oh, i just found your blogspot and it says its a 93, haha
Wait, the body styles are the same to 99 so i guess its the exact same door isn't it?
Ya, its a 1993. Im swapping the dash and the door panels. I will be swapping the seat once I locate some grey buckets or the 60/40 split bench with console, or the 40/20/40. Panels should fit the doors fine considering they are the same doors.Originally Posted by ddawgnd
After I get my engine done i'm planning on doing the exact same thing. I hate the looks of the boxy dash in there right now.
Do you know if the air vents are in the same location as well?
Its all different, you'll just use the vent duct work out of the newer dash.Originally Posted by ddawgnd
Awesome, make sure you do a thread cuz it will definitely help me out when i'm doin mine! lol
