Results 1 to 14 of 14
Is this possible to do? How easy?
This is a discussion on Is this possible to do? How easy? within the Interior Tech forums, part of the General Discussion category; I want to make a custom storage box on the left side of the steering column in the dash plastic, ...
    Nov 2007
    Fort Worth, TX
    I want to make a custom storage box on the left side of the steering column in the dash plastic, down by my legs. It would be made of metal, open with an electric button (solenoid operated?), close the same way, and when closed, just blend in with the dash, so it's hardly noticeable. Needs to be about 5 inches tall by 3 wide. Possible? Easy? If it's hard, how do I look for a place to do it for me?
    Registered User wsigo's Avatar
    Apr 2007
    Hill AFB, UT
    Re: Is this possible to do? How easy?
    Take the cupholder out of the center console, and store your drugs there.
    Will
    '96 Silverado, Emerald Green Metallic/Tan, Z71
    Ext. cab, sportside
    '02 Focus SE Sedan, Toreador Red Pearl, 5 speed, 2.0 SPI (My gas sipping beater car)
    Nov 2007
    Fort Worth, TX
    It's not for drugs. It's a secure place to put my pistol though when I go to places I can't carry
    Nov 2007
    Fort Worth, TX
    my sig...
    I'm in the Marines...I'd get kicked out if I did drugs.
    Aug 2007
    ontario
    what year truck?
    some of those dash pieces down their have stuff behind them that can be moved. you could cut the dash and make them somewhat blend in.
    Ill check my truck tonight and see what sort of space you have back there, but mine is a 1992.
    Added: does it have to lock, and would you want it to open only if the ignition is on?
    Formerly Redneck Rebel Dale Gribble's Avatar
    Dec 2006
    Lima, OH
    In Ohio its highly illegal to install a hidden compartment in any motor vehicle... that said i welded a strong box to the floor of my old regal for securing a firearm when i delivered pizza's. Since the box was out in the open on the passenger side floor board it wasnt able to be considered a "hidden compartment" Not a very aesthetically pleasing solution but it was my delivery car and not used for much else
    "The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
    ~ Thomas Jefferson
    Jan 2006
    The =305=
    If you have an Extended Cab pull those tubby's out of the back sides there is a ton of room in there. The can fit a 1 liter bottle of Bacardi per side.
    98 C1500 EC Step Side: 350, DI/DO Magnaflow, K&N filter, 3.73's, 33x10.50, 15" Cragar V-5, 4" susp. lift, 1" body lift, red top, big 3, rollnlock, halo head lights, clear corners, black tails, cb/pa, light bar
    Joe
    Joe is offline
    MichiganClassics.com Joe's Avatar
    Sep 2001
    Detroit
    Thread edited.
    This is not a thread about which gun laws are better or even preferred
    Please re-read what the original poster is asking and keep it on topic and LEGAL.
    Thanks
    Needs a Updated Pic DarkSilvr's Avatar
    Jan 2007
    Forest Lake, Mn
    seems like a lot of work. probably cheaper to just get your concealed liscence and put it in the door pocket so its still in reach
    Registered User ChevyCanuck's Avatar
    Jul 2007
    Ottawa, ON, Canada
    As stated earlier it would depend on what year your truck is. Different trucks have different things behind the dash panels. I know in my 06 there isn't much room. If I took out the metal plate that sits behind the lower dash piece then I would have tons of room, but it would expose my ignition harness, and bcm. So it depends on the truck, what year is yours?
    Tuning is easy once you've had a few beers
    Registered User DirtyGmc's Avatar
    Mar 2005
    New England
    theres a lot of obstructions behind that area in an OBS as well.
    but like said before, if you have an OBS ext cab then those pockets in the back would be a great place to have a custom, lockable compartment.
    1998 GMC K1500
    2009 VW Jetta TDizzle
    My Flickr
    Registered User chevy6490's Avatar
    Jun 2007
    Maine
    Bolt a safe to the passenger floor panel. That will take care of your problem.
    2008 Silverado Z71 Max, L76 6.0, 4L70E, 14bolt Rear, BlackBear AutoCal, Intake, Actuated Strait Pipe, Leveled, LineX, Detroit TruTrac
    Not active, no PMs
    Jun 2003
    West KY
    I thought about this on my way home, as my dash is apart right now... If you have an obs, you could build a box under the steering column. There is a panel there that has two screws in it and drops out. There are some wires and harnesses there, but it would give you enough room for a handheld and should still be out of the way when climbing in. This might give you an easy "bolt-in" option. You'll prolly have to fab some tab on top of it if you were to use the original setup like the panel has, but it wouldn't be too hard I don't think.
    1988 Chevrolet Silverado - Sold
    Project 88 Thunder Build Thread
    1987 Pontiac Trans Am [Restored]
    1988 Pontiac GTA
    2005 Trailblazer LT
    GASBRNR
    Oct 2002
    Three Blocks Down From Hell
    I've alwars thought about this too. Need somewhere to store my glock. I've thought about building a box that would slide out from under the drivers seat. That might be an option for you. I wanted to build it with a drawer on slides and then cut foam out to the shape of the pistol to keep it from sliding and then carpet the outside to match the carpet. It would be concealed and look factory.
    2006 Chevrolet 1500 Crew Cab 4X4
    1979 Chevrolet C10 2wd
