If it doesnt have the harness all you need is a power and a ground. Just tap in from the dome light and you should be ok. Thats what I did in mine.
This is a discussion on Over head console wiring within the Interior Tech forums, part of the General Discussion category; I recently put an overhead console in my 94 5.7, heres my question. I was hopeing the wiring harness would ...
I recently put an overhead console in my 94 5.7, heres my question. I was hopeing the wiring harness would be up there but I didnt see it. am i wrong? should that harness be up there or do i need to wire it myself?
1994 Z71 - 6" Fabtech w/35's, MSD Ign., Headers, Memphis 12's
*New to the family* Traxxas E-Maxx
-Drew
http://www.facebook.com/#!/newdrewman
'06 CC Z71, 6" RCX, 35" Trail Grapplers, 18" Addicts
'91 Stepside, LT1, 5"-6", 20" Coys, painted interior, etc.
'93 RCSB, 5.3L, 5 spd, 5-7, 20"s (SOLD)
Sorry SoCal, this is off-topic, but were the mounting points already in the headliner? I've got the same truck and just got a console for it.
1994 K1500 350
K&N Open Element, MSD 6A, Cobalt SS E-fans, BFG A/Ts, Cat-back duals, TSX HID retrofit
Originally Posted by Jim
I Had to cut the mounting holes for mine.Originally Posted by neevnav
2009 GMC Yukon
I've read that some 93 and 94 ext cab trucks do have the mounting brackets for the overhead console though.
1994 K1500 350
I ran a single 22 gauge wire to the console (map lights) and grounded the console to the same screw its held to the cab top with. Simple as can be.
1995 Silverado - ported vortec heads, 4L80E, efans, LT4 Hot Cam, Rear disc brake conversion w/drilled and slotted rotors
1999 NBS Silverdo - transgo HD2 shift kit, 3 inch dynomax ultra flow, Ford keys and 305/70-16 Mickey ATZs
My 94ec had the holes in it all you need is the speed clip for the screw.
yup, just need to cut the headliner and slide it inOriginally Posted by neevnav
Originally Posted by rainman318
Thanks again oldred
I used a keyed wire because those are the only real overhead lights I use and I'm notorious for leaving them on so I figured if it was keyed it shouldn't even be an issue.
