inside or outside?if inside just drill the rivits off and pull the rods off in the back and dont lose the little plastic clips on the ends of the rods. put it back on the same way u took it off and use screws where the rivits were
This is a discussion on help changing interior door handle in obs within the Interior Tech forums, part of the General Discussion category; i broke the drivers side door handle. i have the new one... it was like $14 at autozone. i dont ...
i broke the drivers side door handle. i have the new one... it was like $14 at autozone. i dont know how to replace it with the new one. i got the door panel part down but does anyone have a sticky or something. im not dumb just wanted some tips and wanna do it right the 1st time. thanks!
2004 Tahoe Z71 Pat G tune
1998 Silverado C3500 CCLB 2wd
95 Z71 5.7 A/T, 03 Yukon 5.3 A/T
yeah what he said!
Kevin Tolliver
67 SWB Drag Truck Best 1/8 5.78 Best 1/4 9.16
02 2500hd CCSB 4x4
Car Stereo Guy
Mobile Disc Jockey
Drag Racer
I have to do this too, does the autozone handle match the factory one pretty good, or should I go through the stealership to get it?
1996 C1500 ECSB
1988 Mustang GT vert'
1996 BAJA 240 Islander
i dont know about autozone but the ones from lmc do
yeah, trying to find one local though so I wouldn't have to wait.Originally Posted by ruger4d4
thanks though
1996 C1500 ECSB
In case it helps, here is what things look like on the inside:
By the way:
Ruger4d4,
I am jealous of your truck – that is a very nice looking OBS.
'97 GMC Sierra K1500 Z71 5.7L ECSB
Pull off the door panel, then you can unbolt the back steel backing, but it won't want to come off because of the door lock linkage. With a buddy I was able to disconnect the linkages behind the black steel back part and manuever the new one in and connect it.
